Trade: siding windows soffit fascia
Commercial Windows Question
Looking for a source for commercial grade energy efficient windows to install for a county govt. project in a concrete block building, brick veneer. 53 windows combo picture top, awning below.
Up to this point we have barely gotten our feet wet in residential window replacement installs but I have an extensive history in construction. We can handle it. This is a prevailing wage job for county govt. Any tips on this from you guys that have done some county work. Be a real nice job for us!!! Winter quite slow around here. Be able to keep the heat on at home this year. Have to have the bid in by 10:am Friday the 9th! They just put out for bid! Thanks for help, Dave
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors |
Re: Commercial Windows Question
Pella, Marvin & Eagle are pretty popular around here in town halls, librarys, police and fire and such especially on remods. Also check with a regional manufacturer if your looking at vinyl. Make sure once you have all the specs you let the window company give you a formal written cost for the project don't rely on their price books or other info, and make sure they guarantee the prices through the actual construction date.
I found a couple of glass companies here in Central Mo that can make energy efficient aluminum windows to fit the openings. Expect them to be up the charts on $$$$$.
I'm looking around for some gray or silver exterior vinyl (painted with warranty) that may work as they will be considerably more affordable. Some are telling me that it's too large of a hole for vinyl without some support between windows. Then some say their's spec out so must be stronger frames. Wind is the issue, there will be no bearing weight or anything. Hope you all are finding some cold weather work! Dave
#4 | |
Insert title
Trade: Doors-Windows-Decks
Re: Commercial Windows QuestionQuote:
The painted coatings on vinyl have not been around that long, I'm not sure about it yet. Some companies offer a colored vinyl that bonds to the vinyl window. The company that I use has it in a brown almost black color. How big are the windows?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
most are in sets of three like this:
52x52 36x52 52x52 the 36x52 is in center Dave
#6 | |
Insert title
So 2 mulled awnings with a small picture window mulled to a single awning with a picture on top mulled to another 2 awnings with a picture. Are these divided or is the opening actually 156" wide. If so see how long of a unit the window company will send, some get worried about shipping/handling big units. Do you have specs on what they require for DP ratings?
#7 | |
Have no specs at all. It's a weird bird out here in the Missouri hills. What do you know about a vinyl that might come closse to that alum. look? Take care, Dave
#8 | |
Insert title
There are a few companies that offered crappy painted vinyl windows. Don't quote me but I think certainteed is one of them that I was picking on. You might want to post this question on the vinylwindowforum, some of the dealers there might have a source for good colored windows.
You've got me on the DP codes? wazz zat??
I'll try that vynalwindeefrom. Thanks Dave
Trade: glass and window company
DP is the pressure rating of the window. You need to make sure that the vinyl windows that you bid can withstand the DP rating you are spec'd for. Most residential vinyl windows are not meant to be used in a commercial applications lets say above a 4th story. Amerimax is a window manufacturer in the West that does painted product. Not sure of the DP ratings or availability in your area, but they have a website.
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Windows - Blind Inside? | MHMConstruction | Windows, Siding and Doors | 12 | 02-20-2010 01:50 PM |
| Weather King Windows Compare With Pella Windows | SHORTGUN | Remodeling | 2 | 12-09-2008 10:38 PM |
| Windows - Blind Inside? | MHMConstruction | Remodeling | 9 | 10-06-2007 04:53 PM |
| Commercial exterior quote question | back@it | Painting & Finish Work | 2 | 05-27-2007 10:31 PM |
