Leo
Trade: Snl Construction Company
Cemplank Siding ?
Have Some Questions About Cemplank Siding What Is It And Is It Expensive Per Square And Does It Install Just Like Hard Board Siding ? Any Comments Would Help Thanx
Bah Humbug!
Re: Cemplank Siding ?
I've never used it but I do think it is a fibercement product.
Installs the same as hardboard siding, pretty much. You will need a special blade for your cutting tool of choice, or else you will not get very far.
We recently did a garage with this type of siding, going into standard wood framing you can use an air nailer, but we also had to side the walkout lower level which was foam-block formed concrete. We applied the siding with decking screws, which worked but proved to be a pain in the arse as well. |
Hardiplank fiber cement board. Great product. I use roofing nails 1 7/8" for installation. One coat primer & two coats paint. Make sure to use 5/4 boards on all your corners and for freeze boards at top instead of 1" otherwise siding will stick out as it overlaps.
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE | Grumpy | Help Wanted or Looking For Work | 4 | 05-26-2009 03:51 PM |
| Watertight integrity of viynl siding? | mci2980 | Windows, Siding and Doors | 71 | 11-24-2007 04:15 PM |
| siding over wood siding | 72chevy4x4 | Windows, Siding and Doors | 2 | 05-07-2007 05:26 PM |
| asbestos siding | bill6078 | Windows, Siding and Doors | 4 | 03-05-2006 11:33 AM |
