Cedar Siding Removal Bid Help
Old 09-26-2006, 08:47 PM   #1
haskl33's Avatar
I am bidding on the removal of 1000 sq's of cedar siding and trim on a 10 unit apartment complex. All siding is on the second level. First level is brick. Only 2 story apt buildings.
At first they wanted 4 guys at $12/ hr but after I showed up to talk to the apt. manager we thought we'd go with by the sq. They already have a company lined up to install so all we will be doing is removing the cedar siding and trim and installing tyvek.
The job is 1000 sq's... 10 separate buildings in one complex.
I was wondering if $50.00 a sq to remove and install tyvek (not buyinh any materials) is a good number. Or higher or lower?
Also when writing the bid, since this is going to be strictly labor what type of payment schedule would be best? After each building is removed and wrapped? This is what I was thinking.
Any suggestions from the experienced out there would be greatly appreciated.
Thank YOU
haskl33 is offline
The Following User Says Thank You to haskl33 For This Useful Post:
Pro sidder 1 (07-02-2009)
Old 09-26-2006, 10:28 PM   #2
Shellbuilder's Avatar
Trade: Shell building contractor
Re: Cedar Siding Removal Bid Help
How long will it take you to do 10 squares and how many people?
www.shelladditions.com
Shellbuilder is offline
Old 09-26-2006, 11:28 PM   #3
Moderator
Double-A's Avatar
Damnit Shell! I was gonna ask that!
New York Times, July 20, 2006
Double-A is offline
Old 10-10-2006, 08:35 AM   #4
MarkNoV's Avatar
Trade: Windows & Doors
[QUOTE=haskl33;136717]
/QUOTE]
Ask yourself, why would the siding company pass on the removal and Tyvek?
Mark
MarkNoV is offline
Old 10-10-2006, 10:20 AM   #5
joasis's Avatar
The only caution I would look for is the fact you would be on a scissor lift or scaffold, and it may prove tricky to move as needed. Stretching the Tyvec will be a bear, so I would be thinking about how much equipment, how fast to set up, etc. With what little you have stated, I would guess 10 square a day x 4 guys....if they can work the height with no problem.
If you have to rent, a telehandler with a manwalk...maybe 16 feet long, would be the way I would hit it...that way you could pull the old siding and drop it in a dump truck under you, and 3 guys could work fast. Same way with the Tyvec install. Good luck.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 12-16-2006, 09:45 AM   #6
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Insurance, workers comp, and dumptser fees?
osborn is offline
Old 07-02-2009, 11:28 PM   #7
Pro sidder 1's Avatar
Trade: Sidding contractor
Hi , I run a 6-9 man crew and I am intrested in the job I also have a labor cleaning all day so the site will be clean . I have insurance/workers comp etc my number is 630-329-9471 if your intrested just give me a call anytime , thanks .
Pro sidder 1 is offline
Old 07-02-2009, 11:46 PM   #8
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
Iwill do it for cheaper than him
knucklehead is offline
Old 07-03-2009, 12:12 AM   #9
BuiltByMAC's Avatar
Trade: Construction
Not sure what a pro sidder is, but if that job hasn't been completed by now...it never will.
The OP asked that question in '06.
Mac
BuiltByMAC is offline
Old 07-03-2009, 12:27 AM   #10
BobsLandscaping's Avatar
Trade: Landscaping
I love this site.
BobsLandscaping is offline
Old 07-03-2009, 12:33 AM   #11
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
I'll do it cheaper then him /\/\
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 07-03-2009, 12:40 AM   #12
Trade: Landscaping
You're going to do the job cheaper and then do him?
Old 07-03-2009, 11:25 AM   #13
enforcer's Avatar
Trade: windows-siding
i'd go a bit higher than 50 per sq because you are installing tyvek and you need a dumpster/dumpsters. id go in at 60- 65.
enforcer is offline
Old 07-03-2009, 11:55 AM   #14
Tech Geek
Ok Bob, why does everything you read remind you of gay things????
Hint.....
-Dennis
www.bowmanch.com
Old 07-03-2009, 12:22 PM   #15
rwa's Avatar
Hask, I do siding on apartment complexes all the time. I'd say you are low at 50 per sq. Factors to consider; can you just go in and remove the siding at your pace or can you only work as fast as the installer? What about hidden damage? If window framing is rotted will you get a change order or will you have to wait on the installer to submit a change order and do the repairs? Work hours, most complexes want you to stop work at 5pm. That's when their staff leaves and the residents come home. Generally they will not let tou begin before 9am. I've often said, if I could make a living just doing demo, I would, not much to the punch list. Few complexes pay within 30 days. Should you want to contact me, if I happen to know the management company, I will give you info on how well they pay.
rwa is offline
Old 07-03-2009, 12:39 PM   #16
Tech Geek
rwa,
This thread is almost 3 years old.
-Dennis
www.bowmanch.com
Old 07-03-2009, 12:40 PM   #17
Warren's Avatar
Trade: framing/remodeling
rwa,
Yeah true but they probably work really slow at $12 an hour.
Warren is offline
Old 07-03-2009, 12:43 PM   #18
rwa's Avatar
rwa,
dang, didn't notice that, just saw several recent posts ... we, perhaps by now he's been paid
rwa is offline
Old 07-03-2009, 12:45 PM   #19
Warren's Avatar
Just noticed the guy who dug up this old thread. His screen name is pro sidder. What is a sidder?
Warren is offline
Old 07-03-2009, 12:46 PM   #20
Tech Geek
That wouldn't even support my tool habit.
-Dennis
www.bowmanch.com
Products for cleaning cedar siding? rangie Painting & Finish Work 2 07-24-2007 04:34 PM
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 06:47 PM
cedar siding backer question Home Serve Windows, Siding and Doors 7 04-26-2007 02:09 PM
OLD unprotected cedar siding DeanV Painting & Finish Work 4 11-13-2006 08:36 PM
Cedar Siding estimate help SOSSW Windows, Siding and Doors 17 04-26-2006 07:50 AM
