Cedar Shingles
cedar shingles, do you use nails or staples? Although staples are cheeper I think they make the shingles curl up faster. any thoughts
Trade: Exterior Finishing
Re: Cedar Shingles
Staples. Using nials make the shingle cracks therefore the hold isn't as permanent.
Re: Cedar Shingles
16 gauge 7/16 crown staples blind, and coil nails for face nails
Re: Cedar Shingles |
Re: Cedar Shingles
Ummm, I dont, thats why its called face nailed. We face nail under windows, and on shingles cut to fit along the rakes
#6 | |
Re: Cedar ShinglesQuote:
I only use coil nails when blind nailing. Who wants to see big nail heads shining all over the place? Same reason finishers don't use nails with heads. They introduced brad nails and adhesive some time ago. |
#7 | |
Now, when we do shakes, they are usually stained. the painters stain right over the nail heads. Never had an issue. Glue will cause the shakes to crack, and good luck using a finish nail when the shakes start to curl and move around.
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| cedar shingles | wink | Roofing | 22 | 10-08-2008 07:36 AM |
| Pressure treated and cedar | pfloyd | Decks & Fencing | 4 | 05-31-2008 12:46 PM |
| Owens corning a solid strip of tar | nolo | Roofing | 26 | 01-29-2008 01:25 AM |
| roofing over cedar | jkdon | Roofing | 24 | 03-16-2006 09:26 AM |
