Caulking
Old 03-23-2008, 12:10 PM   #1
davinci's Avatar
Trade: roofing
Caulking
you guys caulk the int after painting or staining? staining we basically have no choice but anyone wait til they paint before caulking?
davinci is offline
Old 03-26-2008, 11:49 PM   #2
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
Re: Caulking
caulk is paintable , stain you should use wood filler that matches the type of wood . shold be done before staining/painting
odellconstruct is offline
Old 03-27-2008, 09:21 AM   #3
davinci's Avatar
Trade: roofing
Re: Caulking
you guys always caulk the int of window BEFORE you paint or stain?
of course using a wood filler means you stain after the filler but if we are using latex clear caulk,the caulk goes on AFTER the stain?
davinci is offline
Old 03-27-2008, 11:53 AM   #4
Patrick's Avatar
Re: Caulking
Your caulking should never be visible. so it shouldn't matter when or what you use.
The only visible caulking would be if the trim was being painted and the painter used painters caulk and then painted over. But gennerally, all of our caulking on the inside and outside is hidden. Exposed caulking looks like crap. ESPECIALLY Clear caulking
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-27-2008, 12:05 PM   #5
DavidC
DavidC's Avatar
Re: Caulking
Ditto what he said.
Good Luck
DavidC is offline
caulking cracks on stucco is extremely noticable saucedo80 Painting & Finish Work 6 09-19-2011 01:01 AM
Bathtub Caulking Type Jodi M Construction 21 12-12-2008 08:34 AM
Commercial Caulking Ryanl Commercial Construction 3 11-09-2007 10:06 PM
How long do you warrantee your caulking Pearce Services General Discussion 5 05-30-2007 10:09 PM
Caulking didn't hold up. KellyPainting Painting & Finish Work 13 03-14-2007 08:47 PM
