Walsh Construction Svcs.
Braking Metal For A Brick Exterior?
Had a potential client call me today to finish off a set of french doors that her husband put in. The door is vinyl with a channel to accept the metal on the door side. The gap between the door and the brick is small (< 3/4") and there is just some fiberglass stuffed into the gap between the door and the brick. My question is how do I secure the metal to the brick side? I'm guessing just bend the metal into the channel of the door and try to butt the metal as best as I can to the brick and caulk? I have done some metal work in the past but it's not something I do everyday (or even every month!) and have never had to work against brick. Any suggestions will be greatly appreciated!!
Thanks! Lance |
Re: Braking Metal For A Brick Exterior?
come on! somebody's gotta have come across this before. Am I thinking in the right direction or am I bassackwards again
?Thanks. |
It is what it is
Trade: Roofing, Remodeling, Concrete
can you cut out a mortar joint and tuck the metal in and re mortar or caulk it?
You are at one of those "head scratching moments" where we get creative.
Trade: Licensed Home Improvement Contractor
Ive done something like this with stucco- I snapped a line around the door at the width I wanted. Used a hand grinder and cut a kerf into the stuccol( brick in your case). Then bent my metal to return into the kerf. .
#6 | |
Trade: general contractor
Re: Braking Metal For A Brick Exterior?Quote:
It is what it is
It would help if we had a picture to get an idea if possible.
When It Rains, It Pours..
Trade: Remodeling(Everything)
Just run furring strips on the frame against the brick then cap it...I don't caulk against any brickwork...unless I have tooo.....
#9 | |
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| brick work on exterior of fireplace | qwert | General Discussion | 12 | 07-24-2007 06:19 AM |
| Exterior brick slurry/painting | jwaldman97 | Masonry | 10 | 09-23-2006 04:41 PM |
| Paint exterior metal railing | navco1390 | Painting & Finish Work | 3 | 07-09-2006 08:07 PM |
