Trade: remodelling
Blown In Cellulose Versus Blown In Fiberglass?
which is a better insulation?
thanks stan |
Trade: Home Improvement
Re: Blown In Cellulose Versus Blown In Fiberglass?
Cellulose is better for your health......
Bob |
I'm with bob for a few other reasons. Cellulose is recycled. Anybody that ever has to go into the attic will thank you for it. It is also better insulation.
Trade: remodelling
thanks guys,just want the best r value!
#5 | |
Finish Carpenter
Trade: Finish carpentry
Re: Blown In Cellulose Versus Blown In Fiberglass?Quote:
Please elaborate on this. I have heard nothing good about cellulose because of the fire treated material in it (Boric Acid) and god knows what else. I read somewhere is was 30% chemicals. I also read that alot of them news papers that are recycled are old and the ink they used in the olden days was not good for you... Again, I am just going by what I have read and would love to know why cellulose is "healthier"
Dont hold me to this, but I thought the fiberglass had better insulating properties per inch than cellulose?
Pro: as i see it, the cellulose is alot cheaper and does not cause the severe itching problem during installation and if you ever have to get back up there for running wires/exhaust fan ducts. Cons: cellulose weighs more per sq ft than fiberglass and can exceed the live load on bottom chords/ceiling joist and strain the ceiling sheetrock from added weight to achieve proper R rating in northen climates. Best way IMO is thick poly incased batts, but that's also very expensive to do an average home. |
Trade: remodelling
iwas talking to a friend of mine who has a friend who had blown in cellulose.for some reason the guy had to remove some dry wall a few years after it was built and the cellulose had settled.roughly 5 to 6 inches below the top plate was exposed with no insulation.this has me worried!have you guys ever heard of this?
Heard of it?? LOL, see it quite often when doing remodels or when reframing openings for larger windows/doors. Alot of houses back in the day just had one hole drilled at the top of the wall cavity and the cellulose was blown in, in common thinking, the cavity should fill and pack from the bottom up. In reality it loosely fills the wall cavity and it does not take much for bridging to happen and stop the insulation from completely filling the void.
Modern practices based off learning from the past now have 2 holes being drilled, typically one half way up the wall cavity which fills/packs the bottom half of the wall, then another just below the top plate to fill the second half of the cavity. When homes are done in this fashion it helps try to ensure a complete wall packing that will not settle as much. Just like concrete guys will tell you, the only thing they'll guarntee with a new slab/sidewalk, etc...is that it will get hard and it will crack. Kind of the same thing with blown in cellulose,-it will settle. Just a matter of how much. Typical attic insulation if blown in at 16" for the recommended R value at time of installation will easily compress over time, how much depends on alot of variable, but it will not be the same thickness 10yrs after it was first blown in. |
#9 | |
I did have some respiratory problems from fiberglass and personally just don't like working with it. Reguardless proper handling and installation of all insulation, and it is safe. |
Trade: remodelling
so which route would you guys go if you where building a new home?
If I could swing the money, spray on urethane all the way. It insulates and sound deadens like nothing you can imagine unless you've seen it first hand after the house is built-almost erie how quite the rooms are-even great rooms that had normal echo's prior to bringing in carpet and furniture are dead quite.
Otherwise, fiberglass batts for a more economical solution. |
Trade: remodelling
im not familiar with spray on urethane?is that the stuff there doing now that looks like great stuff?
Trade: remodelling
dont they use that spray on urethane with fiberglass batts?
Once electrical/plumbing is signed off on, they come in with a big gun and hose and start spraying the wall and it expands like Great Stuff and then is cut flush with studs a short time later, it's a stand alone process and is all that's needed. I see lately they've been spraying the bottom of roof decks here too, but would hate to be the guy in 50 years to replace any sheeting if something happened
Trade: remodelling
interesting!what is the r rating with it?
Just did a qucik goggle for spray on insulation, many links, but here's one for reference: http://www.powerhousetv.com/stellent...bu_000575.hcsp
Trade: remodelling
i know there is one contractor for sure in my area who is spraying that stuff 2 inches thick,then putting fiberglass batts over it.
stan |
#18 |
Trade: Energy Auditor, Insulation, Contractor
The environmental advantages are generally from making the product. Using recycled paper is more earth friendly than making fiberglass batts. If I had extra money I would use foam insullation. You can equate a foam insullated house like a refridgerator. No air in or out. But if your trying to make money and build houses(which is why we do this right?), I highly recommend BIB cellulose. This is cellulose insullation that is blown in so tight it won't move. This is different that the older methods that you are seeing in 10 yr old walls. My insulation guy will give me a 90% blower door rating with BIB. Very tough to come close with fiberglass batts. Generally speaking fiberglass is least expensive. Then BIB cellulose (15% more), spray cellulose, then spray foam. Spray foam will be at least 3x the cost of fiberglass. Spray is getting greener also. They make it out of soy. Use BIB cellulose, throw in some energy star windows, and you will see at least 30% least energy used (other factors needed to get these savings) And you won't itch installing it!
#19 | |
Trade: remodelling
#20 | |
Bob |
| blown in cellulose versus blown in fiberglass? | bmf5150 | Construction | 8 | 09-08-2009 10:23 PM |
| For the builders? | joasis | General Discussion | 14 | 04-23-2008 07:39 AM |
| Fiberglass Sideing for Homes | SHORTGUN | Marketing & Sales | 3 | 05-26-2007 12:25 AM |
| Ceramic tile on top of fiberglass pan? | rayn41c | Ceramic & Stone Tile | 17 | 05-23-2007 06:59 AM |
| Fiberglass just not popular in every area.... | ruskent | Pool Construction & Enclosures | 14 | 04-16-2007 11:05 AM |
