Best Way To Install 3/4" Insulated Glass & 1/2" Stained Glass In One Opening
Old 08-16-2009, 12:18 AM   #1
hevnbnd's Avatar
Trade: Masonary
Question
Ok, This is a strange request. I have an opening on a 6" stud wall that is getting both a 3/4" low e piece of glass and a 1/2" piece of stained glass in it. The purpose of the low e is to help the r value of the window. Not sure which piece should go on the inside of the house and which should go on the outside and the best way to space them out. What would be the best way to install this to prevent condensation? This is in Arkansas which can be very humid and hot. Thanks in advance.
hevnbnd is offline
Old 08-18-2009, 01:11 PM   #2
avenge's Avatar
Re: Best Way To Install 3/4" Insulated Glass & 1/2" Stained Glass In One Opening
I'm not a glass installer but I would put the low e on the outside giving the stained glass protection. Then I would only separate it 3/4" to 7/8" the farther away I would think the more it would obscure the view of the stained glass.
Maybe you can have a shop incase the 2 in an aluminum or vinyl airtight frame.
avenge is offline
Old 08-18-2009, 11:24 PM   #3
hevnbnd's Avatar
Trade: Masonary
I thought about the airtight frame as well however there is not enough room in the opening for it I believe.
hevnbnd is offline
Old 08-18-2009, 11:42 PM   #4
Kgmz's Avatar
Have a glass shop triple pane the window, 2 pieces of glass on the outside, stained glass in the middle, with super spacer. Then you can set the glass in any type of frame you want.
Kgmz is offline
Old 08-19-2009, 12:04 AM   #5
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Andersen art glass installs on the inside of the insulated sash.
I installed one several years ago and it's never had a condensation problem. We get very hot humid summers and subzero winters:
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Frameless glass shower build, ideas please rotarex General Discussion 23 12-29-2008 09:57 AM
Pond Water-Leveling Pipe Install Trencher Excavation & Site Work 7 12-26-2008 12:28 AM
3/4" Teak Install fixitpete Flooring 10 11-16-2008 10:01 PM
Septic tank install help metzade Plumbing 6 09-26-2008 09:47 PM
Broken Sliding glass door sprinklerguy Windows, Siding and Doors 10 01-04-2006 04:58 PM
