Trade: EE
Best Type Of Fiber Cement Siding
Looking for opinions on Hardi vs. Certainteed Fiber cement product.
Will be using lap siding application. Need to lap at about 3" to match (sort of) other sides of house. This is an addition. And will paint siding ( again to match existing). |
Siding Windows Doors
Trade: Exteriors
Re: Best Type Of Fiber Cement Siding
There are too many things we dont like with cement board but when we have a choice between hardie and Certainteed we would pick Certainteed. The main reason is the difference of the way the product is cured. Certainteed cures its planks the same way every time and hardie wet cures air dry.
Windows Plus
Trade: Replacement of windows,siding and doors
anybody heard of a stucco cement look sididng?
Trade: Supply
The stucco panel is available from Hardiplank and Maxi Tile, possibly Certainteed but I'm not sure. It's interesting, my customers dont really like working with it. The hardi sheets come 4x8 4x9 or 4x10.
Windows Plus
thanks. I do have a prospect who has a tudor style house. He wants that removed and stucco applied. He did mention the hardi board. Is there a more reasonably priced product in the cement board lines?
Trade: Exteriors
The 4x8 and 4 x 9 cement board sidings need an extra nailer every four foot which makes it a drag for retro work.
#7 | |
Restoration Crazy
Re: Best Type Of Fiber Cement SidingQuote:
We are doing one at the moment, it is a pita! But it is not a requirement to have two nailer's on the seam.Our install has a caulk joint with no batten strip, thats making things tough. We have to take some time to find the right layout. Most sheet products are recommended to have a batten strip over the joint. Next time around I will insist on this detail or not do it at all. The batten will get nailed through to the stud and hold down the edges. You still need to nail the sheets down on the edges even if you use the battens, but it wont be so critical if you chip the sheet once in a while.
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
Trade: Exteriors
www.jameshardie.com/pdf/install/install_panel_north.pdf
Figure 4 shows the best way to nail verical panels to the wall. I have seen vertical siding not installed this way pulling away from the wall after a few years. I dont see any way to nail 3/8 of an inch off the edge of the vertical siding where they meet and leave room to caulk without a double nailer. While its true you can use a batten at the seam (figure 2 )this only looks right if the battens are used every 2 ft oc. in my opinion. There is no way to get nails into the stud off both sides of the siding without a nailer. Last edited by easy sider; 04-10-2008 at 06:46 PM. |
#9 | |
Restoration Crazy
I'm useing the pre-painted sheets for this one. Fortunatly, the materials came scratched up and Hardie has cut me a check to have it re-painted. Otherwise, this would be a ball buster and then some! I will NEVER do pre-finished sheets again! I still love the lap siding though.
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
The sheets are a joke. There has only been a couple small details that I have like using the sheets.
#11 | |
Trade: Supply
The Hardi Sheet should not be as expensive as typically hardi clapboard product |
Trade: Architect
Hardie Board does have a stucco textured panel, but if you don't want it a batten type installation with trim boards over the joints you must provide flashing at all horizontal joints.
A system that provides a completely water sealed installation without flashing is to do hardie board panels and then apply a stucco finish such as the one by Architex. |
Trade: electrician
Nichiha has the best fiber cement sidings. It's not layered. It's one solid piece of fiber cement.
krak |
#14 | |
Trade: Siding installation
I have had nothing but extreme problems with Certainteed. I have installed over 150 units and 90% of them failed. I have installed over 90 units in the Hardi "Color Plus" and 0% of them have failed. I do not believe in the Certainteed "Weatherboard". Certainteed has recently changed the formula in their product to have more Flyash in it. They must have figured out something. Anybody else have problems? I am located in Northern Illinois.(maybe climate issues) Product was installed April 2005 - March 2006. |
Trade: Exteriors
Your not alone with failing cement board siding jobs. Our problem jobs are 4-5 years old with the butt edges on planks failing. No problems except color change with Certainteed.
#16 | |
Restoration Crazy
I can't understand why some seem to have a real problem with this stuff and others never do.
#17 | |
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
I don't think there is a good fiber cement product made yet. But keep installing it, for guys like me we need the future work. thanks |
#18 |
Trade: Siding, Trim
+1 on the Nichiha, it is some awesome looking fiber cement, makes hardie and certainteed look as cheap as vinyl
#19 |
Restoration Crazy
I can't wait to see this stuff! I hear they have a new plant in GA and offer lap siding now. Hardie has recently pissed me off on my last job and cost me big bucks due to delays. Can't wait to try something else. Even if Nichiha is a little more (and it is) I'm ready to go upscale in FC siding. Have you used it yet?
#20 |
Trade: Siding, Trim
No we have not used it yet, I did request and receive a sample pack with some peices in it. It is great looking stuff. I have been to a jobsite here on the coast that used it, it really looks good.
| Vinyl vs Cement Fiber Siding | Dave Buskirk | Carpentry | 11 | 07-05-2007 08:41 PM |
| fiber cement siding paint | pn70 | Windows, Siding and Doors | 2 | 01-23-2007 12:10 AM |
| Framing gun for fiber cement siding? | dantheman | Windows, Siding and Doors | 4 | 12-14-2006 08:34 AM |
| ss110a shear for fiber cement siding? | willbone3 | Construction | 4 | 04-05-2006 10:07 PM |
| Fiber cement siding | TMF | Windows, Siding and Doors | 7 | 01-21-2006 04:03 PM |
