Best Sealant For Vinyl Replacement In Cold Weather
Old 01-18-2010, 08:44 AM   #1
remster's Avatar
Trade: General Carpentry
Rewards Points: 25
What is the best exterior sealant for installing vinyl replacement windows in cold weather below freezing.
remster is offline
Old 01-18-2010, 10:20 AM   #2
enforcer's Avatar
Trade: windows-siding
Re: Best Sealant For Vinyl Replacement In Cold Weather
OSI Quad.
enforcer is offline
Old 01-18-2010, 10:41 AM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
that geocel works pretty good too
Tom Struble is offline
Old 01-18-2010, 04:58 PM   #4
remster's Avatar
Rewards Points: 25
Originally Posted by enforcer View Post
OSI Quad.
Thanks I have some scrap windows, I am going to apply a few different sealants to them in cold weather and see which adheres the best to the vinyl.
remster is offline
Old 01-19-2010, 11:16 PM   #5
windows & siding
HomeSealed's Avatar
Trade: windows and exterior remodeling
Rewards Points: 614
quad
HomeSealed is offline
Old 01-19-2010, 11:40 PM   #6
bconley's Avatar
Trade: Kitchen and bath design+remodel
Another vote for Quad
When I did auto glass we kept the urethane in cooler with a light bulb in in to keep it warm
bconley is offline
Old 01-20-2010, 05:50 AM   #7
ABKY's Avatar
Trade: Windows and Doors
Boss Glazing Silicone. Its Great
ABKY is offline
Old 01-23-2010, 09:58 PM   #8
buckeyeso2's Avatar
Trade: carpentry
Rewards Points: 75
i just started using titebond weathermaster. Extrudes good in cold weather.
weathermaster
buckeyeso2 is offline
Old 01-23-2010, 10:59 PM   #9
KevinD's Avatar
Trade: Windows,Siding,Roofing,Gutters
Rewards Points: 75
I like Solar Seal 900
KevinD is offline
Old 01-25-2010, 04:32 PM   #10
user38755's Avatar
Rewards Points: 250
OSI Quad or Vulcum 116
user38755 is offline
Old 01-25-2010, 05:21 PM   #11
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
I use a heated modified poly that works pretty well so long as I keep it warm until it's applied. If it's really cold (0-20) that means a bucket of steaming hot water and switching the tubes out every 10-15 minutes.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 01-25-2010, 05:27 PM   #12
Rewards Points: 2,000
I load a couple of gallon jugs
of hot water in a cooler
when I leave home.
Keeps caulk all day if I don't
leave the lid up too long when
I switch out tubes.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Tom Struble (01-25-2010)
Old 01-31-2010, 12:30 AM   #13
rpostss's Avatar
Trade: Exterior Remodeling since 1977
Amen on that Neolitic! Regional differences are HUGE as to what we encounter, supply issues, weather, etc, etc, etc.....
Ron
Post Siding LLC
http://dc.kudzu.com/merchant/14181146.html
rpostss is offline
Old 03-17-2010, 09:15 AM   #14
remster's Avatar
Rewards Points: 25
I tried some OSI quad for the first time, wow does that stuff grip! Had to wash my hands with denatured alcohol to get it all off my fingers i used for spreading.
remster is offline
Old 03-21-2010, 05:34 PM   #15
user38755's Avatar
Rewards Points: 250
WD-40 works great for clean up of OSI and about everything else on a jobsite.
The Following User Says Thank You to user38755 For This Useful Post:
Tom Struble (03-21-2010)
Old 03-21-2010, 06:13 PM   #16
Trade: siding
Rewards Points: 20
even good for metal on metal oxidation marks
Old 03-21-2010, 09:36 PM   #17
General Contractor
greg24k's Avatar
Rewards Points: 7,256
Red Devil makes a few types of caulk which can be applied in bellow freezing temperature. One is Silicone Architectural Grade $5 or less a tube and one is clear HPC caulk.
greg24k is offline
cold weather framing inquisitator Construction 22 10-22-2015 09:17 PM
OSI QUAD in cold weather master of none Windows, Siding and Doors 8 12-21-2010 09:04 PM
Cold Weather Mix Specs Southengineer Concrete & Paving 3 01-11-2010 06:27 PM
cold weather and pets boman47k Off Topic (Non Trade) 24 01-09-2010 10:29 PM
Working in the cold weather Cjeff General Discussion 18 12-19-2009 10:03 AM
