Best Caulk For Windows / Doors
Old 02-23-2009, 08:19 PM   #1
davinci's Avatar
Trade: roofing
any opinions on GE silcone II ? ITS SOLD AT HOME DEPOT. I know everyone hates HD but they are open late and always near a job site. i figure this caulk is better than that DAP stuff they sell. we use the GE product for any caulking that needs to be done on the inside and OSI Quad for any outdoor caulking.
davinci is offline
Old 02-24-2009, 09:10 AM   #2
Bah Humbug!
Grumpy's Avatar
Re: Best Caulk For Windows / Doors
I don't like silicon caulk. It's non-paintable. For siding, windows and doors I use OSI Quad. It's available in alot of colors and can be painted.
As far as interiors go, I don't do interiors, but the only time we do interiors is when we install windows. We use Alex painters caulk.
Grumpy is offline
Old 02-24-2009, 11:30 AM   #3
TRC
TRC's Avatar
Trade: Windows and Doors
Pure silicone (i use tremsil) for exterior where it won't be painted: vinyl window to alum. capping and such. OSI quad for paintable exterior and alex plus for interior because it will not crack quite as easy as regular alex. I've found that any latex based exterior caulk, which usually uses silicone as an additive, will turn yellow and crack if it's not painted. The acrylic urethane, such as OSI can be painted but doesn't have to be painted.
BTW: i try not to use any GE products since they do business with country's like Iran, supporting their military.
TRC is offline
The Following User Says Thank You to TRC For This Useful Post:
buddy110 (03-26-2010)
Old 02-24-2009, 04:42 PM   #4
Bah Humbug!
Grumpy's Avatar
And IBM built the computer that managed the holocaust.
Grumpy is offline
Old 02-24-2009, 05:44 PM   #5
TRC
TRC's Avatar
If you care:
http://www.foxnews.com/story/0,2933,322048,00.html
TRC is offline
Old 02-24-2009, 06:39 PM   #6
Bah Humbug!
Grumpy's Avatar
http://www.ibmandtheholocaust.com/
Grumpy is offline
Old 02-24-2009, 11:45 PM   #7
Josh
Out-Sider's Avatar
Trade: Siding / Exteriors
I like to use Sidewinder - seems to expand and contract without cracking. It is a little stickier, but does the job.
www.jbexteriorsinc.com
Out-Sider is offline
Old 02-25-2009, 12:34 AM   #8
Patrick's Avatar
we use tremsil silicone for exterior you never see our caulking beads anyways visible caulking is a big no no for me
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
The Following User Says Thank You to Patrick For This Useful Post:
Tom Struble (02-25-2009)
Old 02-25-2009, 10:27 AM   #9
windows & siding
HomeSealed's Avatar
Trade: Home Performance: windows and exterior remodeling
Quad OSI
HomeSealed is offline
Old 02-25-2009, 08:55 PM   #10
grob62's Avatar
Quad everywhere, Sidewinder if quad not available
grob62 is offline
Old 03-02-2009, 04:26 PM   #11
user38755's Avatar
OSI most all the time. Vulkem for seals to bare concrete, basement windows.
user38755 is offline
Old 03-02-2009, 04:47 PM   #12
davy crockett's Avatar
you use 100% silicone on the inside and the painters love you,,,,,,G.E. is what the banjo player on Deliverance was afflicted with
davy crockett is offline
Old 03-26-2010, 12:33 PM   #13
caybound's Avatar
Trade: Remoldeling, Maintence & GC
GE Silicone II XST IS neutral cure and paintable. Use it, love it.
caybound is offline
Old 03-26-2010, 10:00 PM   #14
Wayfarer Doors's Avatar
Trade: windows and doors/ construction supervisor
I only use Mulco Caulking. Its a "thermoplastic" caulking that self levels(read shrinks) and is toolable for about 5 seconds, but also skins over quickly keeping dirt from sticking to it. Its bubble free and the claim it expands up to 1400% and I think its true. My kids are using old caulk as a sling shot. As for silicone, if I have to use it I take a big gob and rub it in my hair just to get it done and over with.
Wayfarer Doors is offline
The Following 2 Users Say Thank You to Wayfarer Doors For This Useful Post:
all vinyl (03-27-2010), Home Serve (03-28-2010)
Old 03-27-2010, 10:03 PM   #15
topsail's trimcat
woodworkbykirk's Avatar
flex 9000 or quad on the outside, dap on the inside
silcione only for bathrooms where the cut out for the sink in the countertop, counter meets wall and at the floor where flooring meets the bath/shower, glass meets wall in built showers
dap for everything painted inside
woodworkbykirk is offline
Old 05-17-2010, 11:00 PM   #16
SealantEngineer's Avatar
Trade: Windows Waterproofing
should really try using a commercial grade "natural cure" silicone. It seem like the residential market is so stuck on quad. i put up some test samples of quad i my shop and it adhered nice at first but fail in about 6 months and took about a 25-30 shrinkage. try using dow cornings cws...
swrionline.org/validation/products_sealants.asp
If the sealant you use isn't in the above links list, you should consider changing to one that is on the list... SWRI is GOD in the sealant world, if they dont validate a sealant product you should avoid it like the plague...
SealantEngineer is offline
Old 05-17-2010, 11:14 PM   #17
KarlV's Avatar
Trade: General Carpetnry, framing
Echo on those recommending OSI Quad. Hard to beat it.
KarlV is offline
Old 05-17-2010, 11:28 PM   #18
superseal's Avatar
Trade: Masonry / Carpentry Construction and Restoration
Quad's the exterior mainstay unless i'm against stucco - then it's knife grade elastomeric sealant - Thoro or Benny Moore in a bulk gun and I'm a happy camper. Excellent toolability. As far as the Quad, if your tooling, (which I do) you better focus on one joint at a time in limited distance or your gonna be leaving skid marks everywhere. Oh yea, don't stick your fingers in it
superseal is online now
Old 05-18-2010, 02:35 AM   #19
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
I think the best caulking you can get for windows is sheet metal, preferably copper but bonderized or stainless would do well and a tin-knocker that knows how to install it.
Andy.
www.draftinginoc.com
ScipioAfricanus is offline
Old 05-18-2010, 10:15 AM   #20
Tom Struble's Avatar
Trade: siding
i have a hard time getting that out of the gun Andyyou really gotta heat it up
Tom Struble is offline
ScipioAfricanus (05-21-2010)
Roll up garage doors Calipainter Painting & Finish Work 20 03-11-2009 03:48 PM
Caulk quality Ralph6 Windows, Siding and Doors 5 09-04-2008 06:33 PM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 06:24 AM
Caulk flat panel doors in cabinets? cstrombe Painting & Finish Work 8 02-25-2007 06:04 PM
