Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 03-21-2008, 05:37 PM   #1
Trade: roofing
basement window install
about to order some basement hoppers. need to be ripped out of cement,no big deal. that said,for a cleaner look,should i order the windows a bit smaller and screw in some poplar or pine into the concrete to use as a frame so it can be painted. of course the window will now go into the poplar or pine opposed to the cement. i think it will look better. opinions?
davinci is offline   Reply With Quote
Old 03-21-2008, 05:54 PM   #2
http://www.contractortalk.com/f33/window-question-you-guys-31931/
neolitic is online now   Reply With Quote
Old 03-21-2008, 05:56 PM   #3
Patrick's Avatar
is there a steel window there now? Or a wood window? If its a steal window, leave the frame and install your window into the frame. If its wood, rip it out down to the concrete, and install a Pressure treated buck frame to install your window into.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline   Reply With Quote
Old 03-21-2008, 06:03 PM   #4
genecarp's Avatar
no use ACQ never pine or poplar with cement (o brother)
genecarp is online now   Reply With Quote
Old 03-23-2008, 10:18 AM   #5
tin man's Avatar
Trade: windows and siding
I never would take out steal frame,have window made to fit.Install will take
no time.
Good Luck
___________________________________
replacement windows and vinyl siding Boston Ma
tin man is offline   Reply With Quote
Old 03-23-2008, 11:50 AM   #6
Patrick's Avatar
Tin Man, what are you doing to finish the inside of the window on an unfinished basement. We've been just ripping 2x4's and ram setting them into the cement around the window after we install it. Do you do anything more attractive?
Old 03-26-2008, 07:08 AM   #7
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
If it's a wood frame what we do most of the time is order the window to fit the cement R O. It give you a little bigger window and a real clean job.
Jake Stevens is offline   Reply With Quote
Old 03-26-2008, 10:44 PM   #8
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
frame opening with wood according to style window used , 2x6 ,2x8 ect measure opening when done , . install window insulate , trim out inside to match existing , bend a cap with a brake for out side making sure sill cap is beveled away from window , helps to use concrete to make a slope before capping , caulk with silicone where necassary
odellconstruct is offline   Reply With Quote
estimating guide for windows? Grumpy Windows, Siding and Doors 9 09-10-2008 07:01 AM
Cut and install new house window mustanger Carpentry 2 11-30-2007 09:40 PM
Cut and install new house window mustanger Remodeling 2 11-30-2007 09:39 PM
difficult window install Patrick Windows, Siding and Doors 14 09-17-2007 04:50 PM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 05:29 PM
