Any Cold Weather Vinyl Siding Tips
Old 01-08-2009, 12:27 AM   #41
Tom Struble's Avatar
Trade: siding
Re: Any Cold Weather Vinyl Siding Tips
the sanding disk work great to cope crown
Tom Struble is offline
Old 01-08-2009, 07:31 AM   #42
Capra aegagrus
Tinstaafl's Avatar
Yeah, I saw that elsewhere on here. Plan to try it out as soon as I find one of those pesky disappearing roundtuits.
Tinstaafl is online now
Old 01-08-2009, 06:28 PM   #43
Home Serve's Avatar
Trade: siding windows soffit fascia
I have been using the same saw cutting jig since 1977. I work all winter in the coldest city on this continent; Winnipeg. (I'm currently on my 3rd. saw, the lightweight 10 amp. Skilsaw 5700 RPM, probably not sold anymore, but any high RPM saw will work) Honestly I have worn out 2 of these, and I'm now on my 3rd. I have it permanently mounted on a two track system that also hinges up and down, the slide is 20" long for most soffit and all vinyl siding used up here. You mount the blade (7 1/4" plywood blade) in the regular way, but you cut backwards, like you do with a radial arm saw. I use it to cut all my trims, vinyl and aluminum siding, cornerposts, soffit, it never chips, but you have to cut a little slower in winter. I firmly believe you are only as good as your equipment, how can you do professional installing if you can't make a decent jig? (I will post pictures) Also you need a decent work table. I do all my lengthwise cutting by marking with chalk line, cutting freehand with a hooked roofers blade, and yes, fine tuning with a small Stanley plane, where a precise fit is needed. Lordy Lordy, I think I will change my signature to "Don't knock it if you haven't tried it" Here are pictures, I would love to also see what others are using, for example: Pro's like Patrick, who "doesn't want to carry around a chalk line"
Thanks much for taking the picture of saw set up and cold weather tools. As far as the block plane goes when that vinyl gets froze up just plane it like wood hey? I'll have to give that a try, I've got a leftover from the old days.
Thanks again,
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 01-08-2009, 06:43 PM   #44
PA woodbutcher's Avatar
Sorry Tinstaafl, mean to quote critter as to what he was using for a disc for siding.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is online now
Old 01-08-2009, 09:27 PM   #45
Instructor, ex-contractor
critter's Avatar
Trade: Construction trades Instructor
I use this or any available 4 1/2" cut-off wheel. I lean toward any that tout "extra break resistant" y'know?A60S 4-1/2" Metal Cutting Wheelby Sait PART#: 22021COST: $2.00 Thickness: 0.045"Arbor: 7/8"Type: Depressed CenterFor fast, burr-free cutting on all ferrous and non-ferrous metals. Hard bond for extremely long life. Unique, thin Type 27 shape can be used on all angle grinders in accordance with ANSI B7.1. Special aluminum oxide formulation offers the fastest cutting, longest lasting thin wheels. Externally reinforced with fiberglass layers to provide ultimate safety in a thin wheel. ...........and almost no melting problems the little there ever is rubs/snaps off clean.
critter is offline
Old 01-08-2009, 09:55 PM   #46
Capra aegagrus
Tinstaafl's Avatar
Wow, did that get chewed up! No problem though; got it.
I don't have any siding work scheduled right now, but I'll definitely give this a shot. A friend and I have a semi-competition going--every time we get together, we compare notes on what new uses we've found for our grinders.
Tags
cladding, siding
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
cold weather framing inquisitator Construction 21 11-02-2008 01:59 PM
Vinyl siding insurance claim question kc brick layer Windows, Siding and Doors 11 09-06-2008 11:00 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
