Any Cold Weather Vinyl Siding Tips
Old 01-02-2009, 08:14 PM   #21
ALL VINYL
all vinyl's Avatar
Trade: VINYL SIDING CARPENTRY
Re: Any Cold Weather Vinyl Siding Tips
Originally Posted by built-right716 View Post
use a paneling blade in backwards or a masonry blade to melt the siding instead of cutting it. before you rip the last piece of siding on an eave, run your hands down the length of the siding where you plan on cutting it a few times to warm it up. Make sure you use a sharp knife. Same for j-channel when you back bend it for a tighter fit, make sure its warm. Whatever you do, DON'T hit your fingers when nailing.
FINGERS DONT HURT UNTILL THEY WARM UP AND THEN
all vinyl is offline
Old 01-02-2009, 09:36 PM   #22
Al Smith
A W Smith's Avatar
oh mine hurt right away.
Hazlet? I spent the first 10 years of my life living in Hazlet. 1955-1965
Easter Sunday in 63 I blew the manhole up in front of 19 West Richard street, There was a problem with defective steel in the gas lines adjacent to the new sewer lines there and i knew it, Well yaknow cartoons back then and everything influenced me. I dropped a match in a pick hole.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-03-2009, 04:16 PM   #23
Smileydog's Avatar
Trade: Siding, windows & aluminum cladding
[QUOTE=Home Serve;560364]Looks like we might be in for a brutal winter here in Central MO. We have several small vinyl siding jobs and so I was looking for tips you have learned over the years to make the job go smoother.
I used to cut vinyl siding longways by scoring with a utility knife along a straightedge, until an ex roofer showed me an easier way: Mark both ends of the sheet, make a small V shaped notch on one end. Hook the end of your chalkline into the notch to hold it in place, then snap a chalk line. Then make your cut freehand along this line, using a hooked blade roofers knife. (This is the older style of utility knife used by roofers and drywall installers.) If you hold your knife at a 45 degree angle to the siding, it's very easy to cut. Then, use a small hand plane to take the bumps off your cut. It's really very fast and easy, maybe everybody does it this way? I always work alone, so I don't really know what method others are using.
"Monster trucks are for people who don't understand wrestling": Red Green
Smileydog is offline
Old 01-03-2009, 06:24 PM   #24
Patrick's Avatar
[QUOTE=Smileydog;569928]
A second utility knife with a hook blade in it,
Chalk line
blockplane
Thats three tools more than I wanna carry around in my pouch with me
Make a pencil mark and cut it free hand with the utility blade! Faster, and requires less tools.
If you cant cut free hand, put your speed square on the siding, find your cut mark, and hold your pencil against the square and drag the square and the pencil along the panel.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 01-03-2009, 10:20 PM   #25
Al Smith
A W Smith's Avatar
i burn through rips with the skillsaw and plywood blade in backwards, rip backwards holding the guard up on an old sheet of plywood bench top. That way the rip has a slightly dull rounded edge from the heat which wont cut my hands to shred's. I don't plunge all the way through you have to just ride the saw backwards over the panel on the rip line. If i go forward its too aggressive, even though the ply blade is backwards it pulls the panel up against the shoe. backwards it pushes the panel against the bench. I know it sounds like a hack way to do it but it works really well. and theres little chance the panel will tear at the corners when you try and hang it in cold weather. Which occasionally would happen when i used a knife.
Al Smith
Old 01-04-2009, 01:25 AM   #26
Smileydog's Avatar
There doesn't seem to be much difference in the two methods; whether to mark with pencil, or chalkline, whether to cut with hook blade or regular utility knife. If anyone were to try a hooked blade, you will find they go thru vinyl siding like butter. The hand plane is handy to keep in your toolbox, because freehand cuts can veer off, and it is a fast way to take off any irregularities. It is not a necessity, but could be used with either method. The hook blade knife is a handy tool, to get into tight places with, say if a cornerpost needs to be trimmed after it's in place. And a chalkline; I'm sure you use one to mark out for your starter.
Old 01-04-2009, 11:22 AM   #27
Red Adobe's Avatar
Trade: Siding, Metal Roofs, and Beer Drinking PRO
My best advise is to make sure its pulled up extremly tight if put on when cold, When it warms it will also grow verticly a bit as well as horizontily.
I have 200 houses i do work on that werent locked in good and I stay busy replacing entire sides when the winds rip them off.
Another thing is to chase the sun.......work east side in AM south midday and west after 2 pm
Red Adobe is offline
Old 01-04-2009, 11:49 PM   #28
Tom Struble's Avatar
Trade: siding
pulling up vinyl sidings is definitely not recommended IMO
the vinyl expands much more in length then width
and most quality siding locks compensate for this movement.
Most likely what your seeing is plate and band shrinkage
causing the siding to unlock or poor installation and nailing schedule
Tom Struble is offline
Old 01-05-2009, 07:03 AM   #29
Patrick's Avatar
agreed.
Patrick is offline
Old 01-05-2009, 12:16 PM   #30
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
i agree too , hang it not nail it .. i also found that you can use your brake to make straight cuts score as if it was a piece of coil .. makes for a perfect cut . ive also seen jigs that suppose to help mark and cut but not a fan of them .. i do it the way everyone else mark and cut freehand with a new sharp blade , and keep it sharp
odellconstruct is offline
Old 01-05-2009, 12:36 PM   #31
Tom M's Avatar
A block plane for vinyl? New one for me. I cant see it being worth the trouble.
Tom M is offline
Old 01-06-2009, 02:14 PM   #32
Trade: siding
there is a tool that slides along the panel with
holes or slots that your supposed to put your knife into
and slide the tool to score your panel.My rips never seem
to be the same on both endstho
Old 01-06-2009, 05:38 PM   #33
Al Smith
A W Smith's Avatar
yes i have one, I don't know why because i never use it. Its in the bottom of one of my bucket buddies, I think?
http://www.malcoproducts.com/product...ngvinyl/sd.asp
which works just like the "rock ripper"
http://www.johnsonlevel.com/jl/product.php?id=sqrsRTS
Al Smith
Old 01-06-2009, 09:15 PM   #34
mattp's Avatar
Trade: roofing
When crimping the last piece for the undersill heat your crimpers with a torch so the sidiig wont crack. I do this on any day below 60
mattp is offline
Old 01-07-2009, 07:40 AM   #35
Instructor, ex-contractor
critter's Avatar
Trade: Construction trades Instructor
As for the locking issue, I've found that a few quick chalklines to hold the 8" interval makes the whole job clean and straight. Cold weather makes the lock a little tighter, but holding the 8" multiple will still keep a clean install no matter what the weather does. Everyone is aware that you hold back a little more out of the channels in cold weather to allow for the extra expansion creep, but keeping to slot centers is more important. Cutting in any weather, I have found that a 4 1/2 inch grinder with a thin disc does a sweet job. I can hold it in one hand and progress in the direction that keeps the wheel pushing down on the siding - never up. It doesn't care about profile, lock lips or nuthin'!. Also works for those wierd corner post top trims that we encounter sometimes. It also works for overlap slots in tall corner post installs. Consider a cordless with a lanyard or hook to keep up on your installation rig to make quick adjustments in case your ground man makes an unheard-of boo-boo on the cut!?? Just takes a little care not to pass too far on inside corner cuts. Anyone esle using a grinder?
critter is offline
Old 01-07-2009, 11:46 AM   #36
Capra aegagrus
Tinstaafl's Avatar
I love my little Makita; use it for all sorts of oddball things. But I have to admit I never tried it on vinyl siding. No problems with the vinyl wanting to melt?
Tinstaafl is online now
Old 01-07-2009, 07:35 PM   #37
Home Serve's Avatar
Trade: siding windows soffit fascia
This sounds like a good idea for easy and portable cutting in most any weather!
I'd like to try it since we already have a grinder.
I can't picture what type of "disc" that you are talking about here. Can you elaborate?
Thanks,
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 01-07-2009, 07:41 PM   #38
PA woodbutcher's Avatar
and what are you using for a disc?
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 01-07-2009, 08:38 PM   #39
Smileydog's Avatar
I have been using the same saw cutting jig since 1977. I work all winter in the coldest city on this continent; Winnipeg. (I'm currently on my 3rd. saw, the lightweight 10 amp. Skilsaw 5700 RPM, probably not sold anymore, but any high RPM saw will work) Honestly I have worn out 2 of these, and I'm now on my 3rd. I have it permanently mounted on a two track system that also hinges up and down, the slide is 20" long for most soffit and all vinyl siding used up here. You mount the blade (7 1/4" plywood blade) in the regular way, but you cut backwards, like you do with a radial arm saw. I use it to cut all my trims, vinyl and aluminum siding, cornerposts, soffit, it never chips, but you have to cut a little slower in winter. I firmly believe you are only as good as your equipment, how can you do professional installing if you can't make a decent jig? Also you need a decent work table. I do all my lengthwise cutting by marking with chalk line, cutting freehand with a hooked roofers blade, and yes, fine tuning with a small Stanley plane, where a precise fit is needed. Lordy Lordy, I think I will change my signature to "Don't knock it if you haven't tried it" Here are pictures, I would love to also see what others are using, for example: Pro's like Patrick, who "doesn't want to carry around a chalk line"
any cold weather vinyl siding tips-100_1869-crimper.jpg   any cold weather vinyl siding tips-saw-open.jpg
Old 01-07-2009, 11:38 PM   #40
Capra aegagrus
Tinstaafl's Avatar
Name it and I probably have it (or you'll make me go out and get it!). Most commonly, I have a thin diamond-coated blade installed, but I also use a couple of other concrete-eaters as well as generic metal cutting blades--which come in handy in a pinch to sharpen up my junk chisel, too.
Haven't invested in sanding discs at all. That goes to either the belt or palm sander.
Tags
cladding, siding
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
cold weather framing inquisitator Construction 21 11-02-2008 01:59 PM
Vinyl siding insurance claim question kc brick layer Windows, Siding and Doors 11 09-06-2008 11:00 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
