Any Cold Weather Vinyl Siding Tips
Old 12-19-2008, 08:27 PM   #1
Home Serve's Avatar
Trade: siding windows soffit fascia
Looks like we might be in for a brutal winter here in Central MO. We have several small vinyl siding jobs and so I was looking for tips you have learned over the years to make the job go smoother.
I have one:
Close in an area with housewrap and use a kerosene heater to warm up the siding sitting on saw horses (gotta kinda keep an eye on things so it doesn't go up in flames, use plenty of common sense).
Do you have any?
Thanks,
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 12-19-2008, 09:05 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Any Cold Weather Vinyl Siding Tips
The only advice I can give is just don't do it You'll make alot of scrap. Upsell fibercement But seriously alot of your custs are going to have to be on a saw. I never tried this but someone told me to try using a cutoff wheel instead of a saw blade for the cleanest cuts.
Grumpy is offline
Old 12-19-2008, 09:05 PM   #3
Patrick's Avatar
we work all winter long. Pretty much have to cut every panel on the siding saw as the snips will crack the panels. Make sure you tip your staging planks over at night. try to do dormers and high areas before you get snow. Clean up really well every night so you don't have to go clean everyones yard in April and make sure you leave extra room for expansion.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 12-19-2008, 09:06 PM   #4
Patrick's Avatar
we use a plastic/laminate blade in our saw works great.
Patrick is offline
Old 12-19-2008, 09:50 PM   #5
marc's Avatar
Trade: Siding, Windows, Roofing, Weatherization
Same here. We work all winter. Use a cutting table and cut a bit slower than you would when it's warm. Not that big of a deal
Marc
marc is offline
Old 12-19-2008, 09:59 PM   #6
Patrick's Avatar
this spot here got a little hairy in the ice and snow
Patrick is offline
Old 12-19-2008, 10:09 PM   #7
Home Serve's Avatar
Patrick, It's obvious you guys do work in plenty of ice and snow. I've heard of that, sawing your cuts in the winter instead of snips. So far we haven't had to do that but we will on the next one cause it is really supposed to buckle down next week.
The one we did today we got 3/4 done and the lady got home and did not like the color she had picked (small job). She agreed to pay us to remove it and re-side with something else so we froze our butts for little today. First time that has happened but we got it worked out. I had everything documented so it was her decision to make. It do put a damper on the day.
Hey what happened to the politics and religion board? Is it gone?
Thanks guys for offering your ideas!!
Old 12-19-2008, 10:19 PM   #8
Patrick's Avatar
As soon as I sign a house I nail two full panels on the house so they can make sure they like the color. since we are months and months out its like my signature when you drive around and see houses with two panels nailed on them.
Patrick is offline
Old 12-19-2008, 10:30 PM   #9
Home Serve's Avatar
I'll be changing my routine after this happened. The way this one came to me was kind of not the usual thing but I'll still be more on the ball about it.
Old 12-19-2008, 10:36 PM   #10
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
Patrick I got two jobs right now with a piece cut in 1/2 both nailed to the wall.
One of them is a 40 sq. job in that alcoa cedar discovery.
Been there to many times not to do that anymore.
Small Jobs obviously no but anything with more than a few square I like to let it marinate over there for a few weeks.
thesidingpro is offline
Old 12-20-2008, 12:07 PM   #11
Tom Struble's Avatar
Trade: siding
try to cut your j and corners to the right length so you dont have to try to trim them when its cold had to find this out the hard way
Tom Struble is offline
Old 12-20-2008, 04:34 PM   #12
Home Serve's Avatar
It was 28 degrees today with a stiff north breeze and we were still cutting with sharp snips. Had to be pretty careful but it worked. J was a little more tricky. Supposed to be 5 degrees on Monday morning tho so that will be it for the snip routine. In fact we won't get out there at 5. I like to see at least a 25-30 degree high for vinyl. Start a little later in morning or do prep or something first AM.
Have good weekend,
Old 12-20-2008, 06:38 PM   #13
mickeyco's Avatar
Trade: Squirrel Handler
any cold weather vinyl siding tips
Wear warm clothes.
mickeyco is offline
Old 12-21-2008, 08:46 PM   #14
Professional
Jlubb's Avatar
Trade: Exterior renovation
Did some siding last week and it was 0-5 degrees plus wind chill. We have so much work we cant wait till it warms up, so we just suck it up. If you can keep your trim warm you should be fine. As far as siding panels go you should be able to cut with snips if they are sharp. Good luck.
Jlubb is offline
Old 12-22-2008, 10:45 AM   #15
Trade: siding
ive started to carry a old heat gun in the truck in the winter not so much to heat the plastic but to warm my numb fingers with me my fingers get very cold the first thing in the morning i think the coated gloves i use hold the cold in but it seems like once i get the numb out there fine the rest of the day
Old 12-23-2008, 08:41 PM   #16
Home Serve's Avatar
Good to hear someone is busy! That's some pretty cold temps for vinyl siding. Good luck to you!
Old 12-30-2008, 06:21 PM   #17
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
i use my sawbuck to cut the panels , cuts fine in cold temps , as for when cutting angles a nice sharp pair of snips help cut through better , i tend to rub the area put a lil friction over the troubled areas the lock portions ect .. if it gets to the point where thay keep breaking time to go home or do something else .. your prob just wasting time and materials
odellconstruct is offline
Old 01-02-2009, 03:33 PM   #18
Smileydog's Avatar
Trade: Siding, windows & aluminum cladding
I have one:
Do you have any?
Thanks,
This is not really a cold weather tip, but it is a way to get perfect centering with vertical siding on an upper gable, where you have one of those fancy attic vents, and it really shows up if the siding is not centered. Plus this method is really easy once you get started. Note: You will need one sheet of hor. siding in the same color: The key to starting in the center: Instead of starting with a sheet of vert. siding, you actually start with two pieces of starter, made up from hor. siding in the same color.
Measure out the length from gable peak to your bottom J, or whatever trim you use. Mark it with your level. Cut 2 pieces of horizontal siding this length. Mark out a line on both pieces 1 1/4" below the nailing strip lip. Reverse the 2 pieces and slip the cut edge of one piece under the lip of the other. you now have a piece of two way starter Cut it into the right length above and below the vent. You can now start installing the siding from the center both ways. One caution, be careful that the sheet on each side of center is clipped in, you may have to fight with one side where the material is doubled up.
I usually use ladder jacks, and planks right across the gable, and you're always cutting 2 pieces (or more) the same length, but moving in opposite directions. Happy installing, bet it's not as cold there as it is up here in the center of the continent. I have a cladding job in progress, with 5 windows done and 6 to go, it's been too cold to work for over 2 weeks.
"Monster trucks are for people who don't understand wrestling": Red Green
Last edited by Smileydog; 01-02-2009 at 04:11 PM. Reason: couldn't stay logged in.
Smileydog is offline
Old 01-02-2009, 05:14 PM   #19
Al Smith
A W Smith's Avatar
Rather than trying to spring a really short panel in place between two J channels or a corner post. leave the top of the J channel loose so you can rotate it to insert your short panel then slide it down and lock it to its installed location. Those foot long or less panels are a PITA otherwise.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-02-2009, 07:18 PM   #20
Master Sider
built-right716's Avatar
Trade: home improvement
use a paneling blade in backwards or a masonry blade to melt the siding instead of cutting it. before you rip the last piece of siding on an eave, run your hands down the length of the siding where you plan on cutting it a few times to warm it up. Make sure you use a sharp knife. Same for j-channel when you back bend it for a tighter fit, make sure its warm. Whatever you do, DON'T hit your fingers when nailing.
built-right716 is offline
Tags
cladding, siding
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
cold weather framing inquisitator Construction 21 11-02-2008 01:59 PM
Vinyl siding insurance claim question kc brick layer Windows, Siding and Doors 11 09-06-2008 11:00 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
