04-20-2009, 12:23 PM
#1
Trade:
general
Aluminum Fascia
I'm contracting a large custom home in Ontario, Canada.
I had aluminum soffit and fascia's installed by a contractor during the colder weather in November. Now I'm noticing, during the warmer days, especially the sides that are facing the sun, that the fascia aluminum is starting to get waves in it, as it heats up and then returns to normal when the temperatures drop. The eavestroughs have not been installed yet. Is there any way to prevent or correct this problem? Did the aluminum installer do something wrong or is this a natural occurring problem due to the fact of contraction and expansion? Will the placement of the eves, stop this ? (There are areas, on peaked gables, that will not have eaves, where this waving, is quite noticeable)
Thanks
04-20-2009, 01:24 PM
#2
Capra aegagrus
Trade:
Remodeler
I assume that you mean you had them wrapped with aluminum sheet metal?
You are correct; in warmer weather, the metal will expand significantly. I know of no way to correct for that problem with metal that was hung in the cold--I try to schedule projects so that any of that work gets done in warm weather.
There are ways of fastening it so that the rippling effect is minimized, but by your description the damage is done. The only way to really make it right would be to remove and re-do it.
04-20-2009, 08:13 PM
#3
home-work
Trade:
carpentry
You can try rehanging, using a "trim nail slot punch" and don't hammer the nails in too tight, stop just before the nail touches the metal.
"I may not be fast, but I am half fast."
04-26-2009, 09:54 AM
#4
Trade:
siding
Aluminum Fascia
Unfortunatly, aluminum is a poor fascia cover, Even under the best field conditions,you may have oil-canning. If I waited till warm weather for these jobs in Minnesota I'd starve to death.So I always try to choose steel fascia, but cant always due to the fact they dont offer nearly as many color options. Gutters are going to help on eave areas, but afraid your'e out of luck on rakes.
04-26-2009, 02:15 PM
#5
Trade:
Exterior Finishing
If you nail the face then there is no remedy for buckling.
On rakes I put a little painted screw through the underside of the fascia making sure the fascia isn't as tight as it can go into the gable trim and also making sure not to screw very tight. We use 5" gutters here so there is no need for aluminum fascia around the perimeter.
04-26-2009, 03:38 PM
#6
Trade:
carpenter
'Homework' is correct, you can rehang the facia but need to use a slot cutter so the facia can move. There is another method - the facia is screwed below with small aluminum screws, and at the top it is insterted into a pressure fit trim. This allows the facia to expand and contract.
04-26-2009, 04:16 PM
#7
Trade:
Carpentry
I've never had trouble with fascia in hot or cold weather doing jobs in Minnesota or the NE. The key is to allow for expansion and never nail into the face of the fascia. I have always used three nails to hold a 10' piece up. Predrill the aluminum to give a little room for movement. Unless you're in a hurrican zone, it won't blow off, which is what everyone thinks will happen if you don't put a thousand nails into it.
04-26-2009, 06:24 PM
#8
Trade:
siding
slot punch?screws?hmm learn something new here all the time
04-26-2009, 06:47 PM
#9
Trade:
residential framing/general carpentry
One option would be to cover it with Azek.
" It's a Jersey thing, you wouldn't understand"
04-26-2009, 08:52 PM
#10
Trade:
Carpenter
you and your azek i swear your a rep. and what if you want more than white? thats all i ever see is white.
But as far as the aluminum nail it loose and don't over load it and stay away from the face
04-26-2009, 08:58 PM
#11
Trade:
siding
but he does it so niiice!
04-26-2009, 09:06 PM
#12
Trade:
Carpenter
indeed he does
04-26-2009, 09:44 PM
#13
Trade:
Azek is very paintable, scuff lightly, prime and paint with acrylic latex. It doesn't absorb water so the paint holds up well.
04-26-2009, 09:52 PM
#14
Trade:
Exterior Finishing
That's what I just said! Jeez if you're from Ontario you think everything you do is original!
04-27-2009, 08:13 PM
#15
Trade:
carpenter
Holey! didn't mean to step on your toe, was making the point about the pressure trim. Is it raining in BC ?
04-27-2009, 08:37 PM
#16
Trade:
General Construction-Plumbing-Heating-Roofing etc.
coil work
Thanks
We use pvc coated coil and it seems to help with the ripples. Three nails per 10 ft is enough most of the time but on high wind areas we will put a nail in the shadow line just below the drip edge.
We also have a brake buddy from Tapco that will put a groove in the face of the coil about 1 or so wide and there is a roller that will duplicate exterior door brickmold. Good Luck
04-28-2009, 08:20 PM
#17
Trade:
Exterior Finishing
No worries mate, just having a go  ! A little rain, though I'm inland so it's never that bad. Heard its already summer in Ontario  .
04-28-2009, 08:44 PM
#18
Trade:
Union Carpenter
Thanks
yes the installer did something wrong you are suppose to install a fascia splice in between 2 pieces and leave a 1/4" gap
04-29-2009, 08:34 AM
#19
Trade:
siding
I've never used a "fascia splice". Is this something you fabricate yourself or purchase? Wonder how the finished look might appear, any pic's?
04-29-2009, 11:18 AM
#20
Trailer park boy
Trade:
Remodeling
"Industry without art is brutality"
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
