Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 04-02-2009, 02:56 PM   #1
Jer
member
Trade: Siding, windows, Aluminum crown
Alternative to caulk
Any ideas on hiding nailheads in fiber cement siding? Caulk just shrinks so much it seems there must be something better out there.
I have never had to worry about it till now as the general always had the painter do all that.
Jer is offline   Reply With Quote
Old 04-02-2009, 04:19 PM   #2
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Well, I would have to ask if you are face nailing the boards or is it just the top row nails and ends? If you are face nailing, you shouldn't be. If it is the top and end nails, I use Drydex and screed to simulate a grain, (if the boards are grained), or just flatten if boards are smooth. Prime and paint. If the boards are pre-painted, I will use the color matching caulk and screed or flatten.
__________________________________________________ ___________
You are not making progress unless someone is trying to get in your way. I will never give up!
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline   Reply With Quote
Old 04-06-2009, 10:43 PM   #3
Josh
Trade: Siding / Exteriors
How big of nails are you using and where?? There shouldn't be many nails to hide, it should be blind nailed when possible. If you need to keep something tight to the wall, use an 18 gauge brad nail - the holes aren't large enough to notice if the caulk does shrink.
www.jbexteriorsinc.com
Out-Sider is offline   Reply With Quote
Old 04-07-2009, 05:28 AM   #4
tomstruble's Avatar
Trade: siding
some of the wider exposures or in high wind areas need face nailing
tomstruble is offline   Reply With Quote
Which Caulk is most mildew resistant? duckdown Remodeling 14 10-05-2009 07:27 PM
To Caulk or not Caulk. HandyHails Ceramic & Stone Tile 11 03-10-2009 06:45 PM
Tub-Tile joint, grout or caulk?? Aframe Ceramic & Stone Tile 8 02-18-2009 12:27 AM
Caulk at tubline... ...or grout? Bazooka Joe Ceramic & Stone Tile 20 12-26-2008 02:39 PM
Caulk quality Ralph6 Windows, Siding and Doors 5 09-04-2008 05:33 PM
