Alside Series 270 Low-e Match?
Old 12-26-2013, 02:53 PM   #1
VinylHanger's Avatar
Rewards Points: 7,260
I have a stupid question considering I'm a glazier.
For the other glaziers out there. What low-E do you use to match Alside series 270 windows from around 6-7 years ago? PPG Solarban 60, PPG 500?
I use to have a chart made up and can't find it. IIRC, I have always used 500, but I may have used Solarban 60 in the past for the older Alpines. I haven't had to deal with many newer Alside windows as they are usually covered under warranty.
VinylHanger is offline
Old 01-08-2014, 01:12 PM   #2
Oberon's Avatar
Trade: Glass and windows
Rewards Points: 93
Re: Alside Series 270 Low-e Match?
I am making an assumption that Alside 270 series refers to Cardinal's LoEČ-270 coating.
Both Cardinal 270 and Solarban 60 are dual-silver softcoats while Sungate 500 is a hardcoat.
270 and 60 should have a reasonably similar appearance while sungate 500 won't be similar in appearance to either of them.
I am also assuming that you are changing out an IG rather than just planning on using a single pane of glass.
Oberon is offline
Old 01-10-2014, 07:28 PM   #3
Yep. New IGU. I called Alside which is always an adventure. They said Solarban 60 was the correct one. This of course took 15 minutes and I had to read between the lines considering it threw the warranty department into a tizzy since they didn't understand what I meant by matching the low-e tint color.
The favored response I usually get is we don't warranty anything before 2001. These were newer and it still was a struggle.
Does anybody remember when you could get a guy, or gal, on the phone that has worked at a place long enough to remember the info you need. It seems that everyone I talk to now is new, or just doesn't have any experience.
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 07:29 PM
Ply Gem series 2000 or Alside excaliber? bensaccount Windows, Siding and Doors 33 04-28-2013 09:04 AM
Anderson "A" series windows mike gunderson Carpentry 5 01-31-2013 10:30 PM
