Adhesive For Vinyl To Vinyl
Old 11-08-2009, 06:23 PM   #1
groundzero2121's Avatar
Trade: General Carpenter
im putting 3.5" vinyl trim around my windows and doors instead J-Channel.....but when i take the miter cut and overlap the square piece....it doesnt lay perfectly flat everytime...Is there a type of adhesive i could dab on the corner to hold them together?
groundzero2121 is offline
Old 11-08-2009, 06:28 PM   #2
Patrick's Avatar
Re: Adhesive For Vinyl To Vinyl
Thats why I try not to use lineals. To answer your question Not really.. You could use a rivet but that looks like crap too
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-08-2009, 06:45 PM   #3
cmon there has to be some kind of adhesive.....i already knew i could prob use a rivet but would rather try some adhesive first
Old 11-08-2009, 06:56 PM   #4
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
miter cut both pieces then caulk the seam if needed.
Darwin is offline
Old 11-08-2009, 07:00 PM   #5
Patrick's Avatar
I hope your joking
Patrick is offline
Old 11-08-2009, 07:03 PM   #6
Patrick's Avatar
As long as you do a better job than this loser. This is the way about 60+ windows looked on a big commercial job I looked at last week. Whole place was a mess soffit falling down, facia falling down, siding buckling everywhere
Patrick is offline
Old 11-08-2009, 08:30 PM   #7
oldfrt's Avatar
As much as I also don't like using the lineals,a little practice goes a long ways in getting it to look good.
First make sure that the starter remains on the same plane all around the window and lays flat.
Sometimes putting a nail under the outside edge starter( leave it sticking out a bit) will help it hold the the starter flush against the window and wall.
Once you get your legnths cut,make sure they don't bind when they overlap each other.
You got to remember this stuff is going to move,and allow for this.
Any tight fits will cause the face to buckle a bit.
As long as the lineals have been laid flat and out of the direct sun they should fit good.
Since this stuff will expand and contract,I always start the 45* angles leaving about a 3/8" square edge to hide any shrinkage.
oldfrt is offline
Old 11-08-2009, 08:32 PM   #8
oldfrt's Avatar
These are the guys that help us get more work!
oldfrt is offline
Old 11-08-2009, 09:20 PM   #9
Lack Of All Trades
Darwin's Avatar
I hope your joking
yeah, joking. well, maybe...
Look. the piece will never lay flat. with expansion and contraction, it will eventuaLLY LOOK LIKE SH!t anyways. the under lap piece? you got to trim and tailor it- to fit. simple.
Darwin is offline
Old 11-08-2009, 09:28 PM   #10
no there has to be some sort of vinyl on vinyl adhesive.....ill search google
Old 11-08-2009, 09:44 PM   #11
Tom Struble's Avatar
Trade: siding
maybe what you would be better off looking for is a double stick tape with a high strength adhesive,
like that pro tape that alumapole sells with the vinyl coil
maybe try the linials that are foam filled?
Tom Struble is online now
Old 11-09-2009, 06:18 AM   #12
72chevy4x4's Avatar
are you installing the lineals according to the manufacturer's instructions? I've only done one job w/ lineals....but performed the cuts exactly to the instructions and after getting 'up to speed' they turned out fine. a miter saw is necessary to get crisp straight 45's.
72chevy4x4 is offline
Old 11-09-2009, 03:01 PM   #13
yes im using a miter saw......i didnt see any instructions included in the box
Old 11-09-2009, 03:01 PM   #14
i think im gonna use a small pop rivet.....alcoa makes them in the same color....it might not be too bad
Old 11-09-2009, 03:21 PM   #15
Trade: siding
that will make it worse
Old 11-09-2009, 03:40 PM   #16
Framer53's Avatar
Trade: Framing
Please don't.
I believe in following directions. No where in the directions does it say to use pop rivit or glue.
Do like someone suggested and buy the foam filled. Other than that, you will have to live with it.
Framer53 is online now
Old 11-09-2009, 06:03 PM   #17
buddy110's Avatar
Trade: Exteriors as a whole
Send a message via AIM to buddy110
PVC cement or liquid vinyl will work
buddy110 is offline
Old 11-09-2009, 06:25 PM   #18
Framer53's Avatar
Trade: Framing
What about the expansion and contraction problem, Buddy?
Old 11-09-2009, 07:19 PM   #19
72chevy4x4's Avatar
I don't recall seeing instructions in any of my boxes of vinyl....except Cedar Discovery.
if you can find the mastic/alcoa installers guide, it has the two page instructions on how to properly cut/trim the lineals-if done properly they shouldn't leak.
Old 11-09-2009, 09:30 PM   #20
Trade: siding
with flashing and flange build up trying to get a lineal to sit flat
is almost impossible, the new construction starter that has the double nail slots and a haunch that accommodates the flange helps but i haven't seen that in awhile
Air waves under new vinyl flooring geospec Flooring 26 05-08-2010 10:20 AM
advice needed on comm vinyl tile job 21gun Flooring 10 08-31-2009 09:30 PM
Tile over vinyl pros and cons tileguy7 Ceramic & Stone Tile 23 01-17-2009 09:53 PM
VCT Adhesive Failure dmranney Flooring 2 12-31-2008 09:53 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
