Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Closed Thread
Old 04-17-2008, 01:51 PM   #1
Trade: general contractor
adding to window framing
Hi all, need some advice on window framing.
I am currently renovating a home that is a bit of a mess with respect to wall width. The house is a mix of plaster, drywall over plaster, drywall over lathe, etc. Needless to say, the wall widths are not condusive to regular sized window jambs. I have decided on drywall rather than PVC jambs to help allieviate that issue.
The second issue that I have is that the house currently has stucco, which we be adding vinyl to. Therefore, I need to build the windows out to accommodate for the 3/4 furring strips/insulation. What is the best way to do this? Do I add to the front of the existing window framing or should I perhaps add say 2X6s or 2X8s (depending on the wall) to the full perimeter of the frame. That would reduce the frame size but would certainly be more secure.
Thoughts?
fumbrunner is offline
Old 04-21-2008, 07:26 PM   #2
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
We would install a vinyl framed window into the 1x6 cedar furring around the window and trim out the inside. This way the siding and the window meet and no wraps are required.
easy sider is offline
Old 04-21-2008, 09:08 PM   #3
Patrick's Avatar
same here cept we use 2x4 or 2x6 to be even with strapping plus foam. Drywall returns look like junk, use wood
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 06-09-2008, 08:08 PM   #4
Trade: Roofing Contractor
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Ed the Roofer is offline
Closed Thread
estimating guide for windows? Grumpy Windows, Siding and Doors 9 09-10-2008 07:01 AM
Adding egress window to concrete wall the catfish Construction 35 02-01-2008 11:02 AM
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
Framing a window opening Davey Framing 13 08-31-2007 05:19 PM
Replacement Window Question? Max10 Windows, Siding and Doors 6 01-11-2007 11:49 PM
