6' Anderson Sliding Doors In Brick Wall
Old 01-23-2006, 03:50 PM   #1
keithguts's Avatar
Trade: Prof. Carpenter
I need to give a price quote to put in a set of thease doors. any one know what the pricing should be. I have put meny of them in, but in wood walls but never in brick walls
Keith
keithguts is offline
Old 01-23-2006, 04:22 PM   #2
i_plant_art's Avatar
Trade: Home Improvments-exterior
Re: 6' Anderson Sliding Doors In Brick Wall
is the r.o. brick or is it framed out with 2x4... what is the exterior consists or siding or brick, or block??
i_plant_art is offline
Old 01-23-2006, 04:28 PM   #3
keithguts's Avatar
The exterior is all brick with a window in the cender where the new door will be going over plywood I belive. The inside is wire and plaster> I do belive it is all 2X4.
Old 01-23-2006, 07:25 PM   #4
well if you have studs on the inside the just install as normally would you will need to get an exterior extension jamb to go with the door. look on the andersen website. and you should be able to find the r.o. size that you will need for the specific door that you are getting, if not let me know and i can get it for you. also are you getting the door or is the client? have you installed one of these doors (specifically an andersen) before?
Old 01-23-2006, 07:42 PM   #5
Remodeler
MinConst's Avatar
What about a header to carry the lost brick? What and how large should it be?
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 01-23-2006, 07:57 PM   #6
bob the builder's Avatar
Trade: Home Improvement
Yeah it sounds like there is a window in the center of the rough opening which doesn't help the least bit. To me sounds like the worst possible senerio for installing... cut 1 side of plaster 1 1/2" shy of a stud and slap on a shoulder, hope the other end works out smooth. Cutting out the brick. Slipping header up in the plastered wall sounds like a treat. Probably going to have some plastering to do, maybe not though. If using engineered product header doesn't have to be as tall...l
Bob
bob the builder is offline
Old 01-24-2006, 01:34 AM   #7
747's Avatar
I had a neighbor who did that just a little bit ago. The guys he hired were peeing me off because they took so long to do the job. I would look out my front window and think thats all they got done. You can see into his back yard out my front window. His house is all brick and they had like one small window there and they had to cut out the brick. Well to make a long story short I was home for two days and they didn't get much accomplished. But when i got back home it was done. But then it pee me off because they didn't have a step there to get down on the new cement patio they pored. That step didn't get put in for like a month. Its just a two step wood running the whole length on the new patio door. But i was home when they put that in it took them the whole day. I was thinking you got to be kidding you guys would have knock that out by LUNCH.
747 is offline
Old 01-24-2006, 09:23 AM   #8
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
sounds like its going in a dining rm
relocate a plug
relocate a heat vent
header change
andersen permashield series w/ standard hwd and screen(don't forget the aux lock nice feature)
shoot him 5400.00 plus the cost of toothing in the brick by others. only an experenced brick man should do this as its critical to the overall look of the product. upcharge accordingly if its frenchwood series. add for paint or stain. oh if hes supplying the door/hwd deduct 1700.00
go dart is offline
SUB-CONTRACTOR needed to build(give estimate) red brick or block(stucco finish) wall( soldz Masonry 18 04-22-2007 09:55 AM
Brick wall Harry I Electrical 18 04-05-2007 04:04 PM
Pipe through brick wall gnahthe Plumbing 12 10-01-2006 01:08 PM
