Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 02-14-2006, 08:50 PM   #1
Trade:
1st time siding?
Hi ,im gunna be attempting siding for the first time i have never done it. im told its not all that difficult? i own the house and its a ranch so that should be a good beginer.
right now there is i belive OSB board up can i just start right over that with the siding or is there some other prep work to be done? also is there any tips i should now for a newbe? tools to use etc.??
thanks in advance.
stringblade is offline   Reply With Quote
Old 02-14-2006, 08:56 PM   #2
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
Vinyl siding is not water proof and neither the VSI or any manufacturer claim it to be. Thus you must install some kind of vapor barrier, usually a tyvek or similiar house wrap. You may also want to consider insulation board based.
Don't nail into the OSB, nail through it and into the wall studs, act like the OSB isn't even there.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 02-14-2006, 10:30 PM   #3
Trade: Home Improvement
thanks in advance.
Now would be be a time to deal with your windows, if it be replace or wrap in aluminium or leave them be. As Grumpy said seal up the water. I would tape windows...
bob
bob the builder is offline   Reply With Quote
Old 02-15-2006, 12:09 AM   #4
Trade:
How thick should the house wrap or insulation board be?
Old 02-15-2006, 07:51 AM   #5
stop botherin' me!
Grumpy's Avatar
House wrap only comes in one size. Insulation board is 1/4" minimum. I wouldn't exceed 3/4" because the windows and door frames will be recessed... then ofcoarse you can build them out if you want to go thicker with the insulation.
-Grumpy
Old 02-15-2006, 10:07 AM   #6
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
Go to www.diy.com for all the answers you need. TG
Pay a professional.
A+Carpenter is offline   Reply With Quote
Old 02-15-2006, 11:25 AM   #7
IHI
IHI's Avatar
Originally Posted by AdamMeider
Pay a professional.
LOL, yeah what he said
It's a great DIY project if you have some basic common sense, but if you've NEVER done it, or have only been a "cut guy" for a freind, seriously consider getting a freind that does this to give you a hand...at least to get it started so he can give you pointers. I've met alot of homies that sided their own place and are happy with it, but once they see how it's "supposed to be done, they realize how screwed up their sheeot actually looks. I'm really biased though because in reality anybody can hang a straight panel with no notches/provisions, but IMO the way J is installed and how obstacles are gone around is what makes or breaks a project. Miter everything for professional look, be sure ALL your J channel interlocks with corresposnding pieces so when it gets cold and it shrinks it does not look any different than when it's 110* outside...hacks just butt J together and it looks like dog ********************t, very DIY imo and pre made corners would be better than that method and they look crappey as well
When you start running courses, ALWAYS double check around the corner to be sure panels on both sides of the building are lineing up...it can get away from ya if you let it. When doing soffit if on a hip roof, ALWAYS start in a dead corner, or a corner that is not in everyday plain view because once you get back around (if your mitering) often the panels will not line up exactly and it looks like crap, so your better off hiding it on a back side corner of the house. Or you can do a hack job and just do striaght cuts so you dont have to worry about it. but then it'll look like an average homie did it.
I like to do all my cap work prior to installing any J channel and will bend a lip back out onto the sheeting so it's essentially got a "nailing fin" and once all the cap work is installed I got back around and tyvek tape over the "nailing fin" on my cap work as an added flashing measure..really important on 2nd stories since I canty remember how many hacks I've had to go out and fix a water infiltration issue due to bad flashing on 2nd story.
Over the years I've heard "siding is easy" and "anybody can side" LOL, well on a dog house yes, but if you want you stuff to look nice and last then not just "anybody can side"...and there are even plenty of siding crews that IMO have no right installing the stuff either but they're the low bid.
IHI is online now   Reply With Quote
Goof Off made a mark? (Vinyl Siding) rorvi360 Painting & Finish Work 10 11-20-2007 12:10 PM
Attaching address plaque to siding ProWallGuy General Discussion 11 07-11-2007 10:29 AM
installing ceder shake(vinyl) versus traditional lap siding 72chevy4x4 Windows, Siding and Doors 1 05-08-2007 07:18 PM
siding over wood siding 72chevy4x4 Windows, Siding and Doors 2 05-07-2007 04:26 PM
cedar siding backer question Home Serve Windows, Siding and Doors 7 04-26-2007 01:09 PM
