Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 02-23-2009, 12:45 PM   #1
The Boss
Trade: Remodelling
100+ y/o siding repair. to run or not to run.
Did a drive by yesterday and it looks like the ho removed a perfectly good vinyl siding and new aluminum fascia to expose this old clapboard . Wants me to estimate what its going to take to repair the siding fascia and soffit back to wood. Im thinking an estimate of time plus mat. and taking draws as i go along. How else would you know how to bid this job in man hours ???
My questions are if you have any suggestions for handeling the split down the side of the house??? Or all of the holes in the siding from the vinyl install (some kind of filler, paint, water tight)?, or replacing the broken/rotten siding (matching it up shrikage, sizing issues, lots of shims) ? I usually install vinyl siding, roofing and windows but this looks like a real challenge.
I called another contractor from the area to bounce some ideas off of and he referred me to talk to a specialist that works with restoring these old wood siding homes out in chicago. Im going to meet with the ho later today to feel em out and measure up. Id love to get this one in the ol portfolio.
Looking for some advise on how to approach this albatross. Thanks in advance for your help
Steve
VALCOR is offline   Reply With Quote
Old 02-23-2009, 12:54 PM   #2
Not an albatross, she's a Queen.
Take a piece of siding to a mill,
find how much to duplicate it.
Find a good painter.
Figure how much replacement,
and how much repair.
Prepare the customer for a large bill.
Last edited by neolitic; 02-23-2009 at 10:12 PM. Reason: spellcheck allows for french
neolitic is offline   Reply With Quote
Old 02-23-2009, 12:57 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Construction
Midtown Tulsa Remodeling
Cole is offline   Reply With Quote
Old 02-23-2009, 09:07 PM   #4
Sean
SLSTech's Avatar
I agree with Neo - or price out removing the siding, sheathing it & using Fiber Cement
SLSTech is online now   Reply With Quote
Old 02-23-2009, 09:22 PM   #5
loneframer's Avatar
Trade: residential framing/general carpentry
Quite a project for sure, don't think I would get involved with a contract price. It's only a trophy house if you don't get buried by it.
loneframer is online now   Reply With Quote
Old 02-23-2009, 10:33 PM   #6
I like the drive to repair the old. But that is me and I am a Green Hippie. I would give an estimate a bit on the high side of 3/4 the price of tearing off and replacing. Then let them know this is on the high side as you want them to be prepared for the worst and receive the best. Also you can talk up how "Green" and responsible it is of them to want to save more trees from being cut down and filling the landfill with the old debris. That allways helps me close a job.
JBMagi is offline   Reply With Quote
Old 02-23-2009, 10:37 PM   #7
tomstruble's Avatar
Trade: siding
looks similar to a project i finished last year but that was a reside full trim replacement with azek
100-y-o-siding-repair-run-not-run-img_1075_2.jpg   100-y-o-siding-repair-run-not-run-img_1263.jpg   100-y-o-siding-repair-run-not-run-img_1265.jpg
tomstruble is offline   Reply With Quote
Old 02-23-2009, 10:44 PM   #8
loneframer's Avatar
Hot pics. Must have been interesting dealing with the flared walls on the turret.
Very clean work, nice job.
Old 02-23-2009, 10:47 PM   #9
tomstruble's Avatar
Trade: siding
few more
100-y-o-siding-repair-run-not-run-img_1277.jpg   100-y-o-siding-repair-run-not-run-img_1276.jpg   100-y-o-siding-repair-run-not-run-img_1280.jpg
Old 02-23-2009, 10:51 PM   #10
tomstruble's Avatar
Trade: siding
what i started with
100-y-o-siding-repair-run-not-run-img_0674.jpg   100-y-o-siding-repair-run-not-run-img_0677_1.jpg   100-y-o-siding-repair-run-not-run-img_0667_1.jpg
Old 02-24-2009, 12:01 AM   #11
tomstruble's Avatar
Trade: siding
picture of the house from 1909
Old 02-24-2009, 12:09 AM   #12
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Was this place cut in half and moved to this location?
I bet that siding is just 1/2"-5/8" straight board siding.
Any Mill shop will be able to re-saw some material whatever it is, for fixing and replacing.
Be useful with Freize boards, add a little bit of trim if you need to.
I used fast-n-final to fill all the nail holes on my old siding that was covered with 2 layers of other siding.
I sanded from 36 to 120, set nails, primed, filled holes, caulked, primed, trim paint, 3 coats house paint. It takes forever....FOREVER....
Make them prove they have the money for something like that.
By the way, she still is pretty!
yes i said pretty
WarnerConstInc. is offline   Reply With Quote
Old 02-24-2009, 12:13 AM   #13
tomstruble's Avatar
Trade: siding
maybe the siding guys channeled it to get a wire buried?
Old 02-24-2009, 12:53 AM   #14
Patrick's Avatar
based on the foundation id say it was moved. That saw cut goes right through the soffit
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline   Reply With Quote
Old 02-24-2009, 01:50 PM   #15
tomstruble's Avatar
Trade: siding
yes it does look like it was Patrick
Old 02-25-2009, 11:47 AM   #16
Josh
Trade: Siding / Exteriors
Definately looks like a T&M job to me. If I were doing it, I'd tear off the worst sections (like the part with the big cut) and replace those with new cedar that matches. Then try to fix up and restore the rest as much as possible. That way they are keeping the historic part if that's what they're going for, but the end result will look nice.
If for some reason they decide to go with Hardie, the smooth finish looks the most like that old siding.
www.jbexteriorsinc.com
Out-Sider is offline   Reply With Quote
Old 02-25-2009, 01:44 PM   #17
tomstruble's Avatar
Trade: siding
thats a good idea outsider
Old 02-25-2009, 05:57 PM   #18
Josh
Thanks...cool house you worked on, by the way.
The Following User Says Thank You to Out-Sider For This Useful Post:
tomstruble (02-25-2009)
Old 02-25-2009, 06:02 PM   #19
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I did a house that had been cut in 2 pieces when I lived in Connecticut. It had been moved by horse teams (at the turn of the century) from one site to where I worked on it. Looked just like your picture.
silvertree is offline   Reply With Quote
Old 02-25-2009, 06:22 PM   #20
Never lost a battle.
ScipioAfricanus's Avatar
Trade: General contractor, designer, drafter.
A wonderful old house, please don't put vinyl on it.
From the pictures it looks like you will have to get rid of all the siding between the windows then re-use some of the longer pieces there. Have some new siding milled to fill in the longer areas and on those longer areas cut back randomly to the centers of the studs at lest 3 bays and fill with new siding and some of the older siding.
This will keep from having one long seam that will be easily seen.
God I would love to do this one.
I have done a couple projects here in the Old Towne district and moving older homes, building new foundations and replacing old siding and milling new. This one is definitely a T&M job.
Andy.
ScipioAfricanus is online now   Reply With Quote
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 06:21 PM
Nailing cedar bevel siding Chris B Carpentry 2 08-25-2008 02:33 PM
How to repair vinyl siding VIDEO Patrick General Discussion 3 01-11-2008 06:36 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
Repair hole in hardboard siding cowtown Painting & Finish Work 6 05-23-2007 01:48 PM
