Service & Repairs
Trade: Electrician
We Need Some New Dimmers Installed
Um, sure, wait right here while I go get them from the truck.
Doofenshmirtz Evil Inc.
Re: We Need Some New Dimmers Installed
Is that how you found it or did it have switches in it?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
Trade: Tradesman / Electrician
Time to start ringing it out, Cha Ching
Gonna need some box extensions as well!!!! |
How about some sauce with that spagetti
![]() Dave |
Service & Repairs
Trade: Electrician
How 'bout we start all over?
The new 6-gang switchbox (3x2x3-1/2" deep old work gems), temporarily spliced until I got the dimmers. ![]() (2) 20 amp homeruns (one in each box), the switch legs, and wires coming from the hi-hats. ![]() The finished product minus one dimmer (and a few plate screws, d'oh!).
All that and you lost 3 screws?
Service & Repairs
Trade: Electrician
Actually, Mulberry failed to put the right amount of plate screws with the face plate. I was there today and still forgot to put the screws in.
And just for the record.... green bonding screws were added to the box and the white conductor was re-identified as a hot conductor. |
screw heads look a little crooked
Curious why you chose type AC cable? Did you just have some handy on the truck that day?
Service & Repairs
Trade: Electrician
Technically, I think I could have used romex throughout this whole building. It's a bar. But the owner was (I guess) was willing to pay a little extra for the armored cable. Actually, a lot more when it comes to the labor of working with AC compared to NM. No plans, no prints, and no CO, yet.
No prints, No plans, No Co etc was this a fit up? Did you do work through out the unit? If so how are you performing work with permits?
If not, What was the 6th switch or dimmer added for? Appears the old set up was 5 switches or dimmers? Also how are the ganged boxes secured on the top? I see you screwed them on the bottom? Don't see any madson bars or such ??? MC also does not appear to be secured with in code next to those junction boxes, was this done after the fact? Another ? where are your grounds on those runs coming into the ganged switch box. Hate to brake B*lls but i know i would be asked if i posted it. Last edited by Stickman; 04-12-2008 at 12:39 PM. |
I don't want to break balls either, but I would point out to you that this is type AC cable, as evidenced by the paper interleaving sticking out with the conductors in the ganged switch box. The armor is the ground for type AC cable. Oops... I guess you screwed up, eh Stickman?
REG EC,CERT EI PLANS EXAM
Trade: electrical
HI MD
Some guys dont know the differnce between type ac,and type mc. We were re fixturing a building for the goverment one of the guys started wining about no ground wire in the mc and it was all illegal and had to be ripped out , He was about 4 years out of his apprenticeship I left him go on for a while, Then after he put his foot in his mouth I made him read the deffinition out of the code book.
Its not that i did not know what it was, I am well aware of the differences. It was more the fact that it is only supposed to be used for fixtures whips above drop ceilings or from a j box to the fixture etc. I was under the impression and taught that this does not include the switch leg. I have also never worked for a contractor that went this route these days, we always use MC. I could be wrong with my statements if so, stating some code would be great.
#15 | |
Re: We Need Some New Dimmers InstalledQuote:
Check out 300's for type MC cable, type AC cable, and FMC raceway under "uses permitted" and "uses not permitted" for each. |
Trade: electrical
Article 320
Thanks learn something new every day.
However Article 320.30B Securing Requires type ac cable to be secured within 300mm (12inchs) of every outlet box, junction box, cabinet, or fitting and at intervals not exceeding 1.4m (4 1/2feet) where installed on or across framing members Last edited by Stickman; 04-12-2008 at 02:09 PM. |
#18 |
Trade: electrical
One misunderstood area from the past, When the nec said no type nm over 3 storys high it never prohibited type ac above 3 stories, its pretty common to see it in appartment buildings ,Personally I would use mc,some people dont tighten connectors and locknuts on bx properly the system is only as good as the mechanic who installed it.
#19 |
Trade: electrical
It aint a mistake till you cant fix it.
The day you quit learning the day you die. |
#20 |
Trade: Squirrel Handler
In Illinois (Chicagoland area) we can't use AC, MC, BX, Greenfield like that, it can only be used for short runs 3' to 5', give or take depending on the Municipality.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
| Flooring Installed Correctly? | white oak | Flooring | 3 | 12-28-2007 07:56 PM |
| Installed Sales | dvon104 | Remodeling | 2 | 07-07-2007 10:49 AM |
| Vertically installed suspended ceiling | Maplehead | Remodeling | 13 | 03-29-2007 10:06 PM |
| Getting a fence installed on Monday!! | Luke's Dad | Decks & Fencing | 4 | 02-20-2007 06:33 AM |
| Here's a few pics of mural we installed last year | jensenconstruction | Painting & Finish Work Picture Post | 6 | 06-25-2006 09:03 AM |
