There's Something Missing
Old 05-07-2008, 12:17 PM   #1
hhasan's Avatar
Trade: Project management, Drafting and design
Good Afternoon,
I'm new to this forum. I am attempting to design a one-line riser diagram (attached) for a small project i'm working on, in Richmond Va. This project has a ground floor commercial space (1500 square feet) with 2 apartments (750 square feet each) on the second floor. The total power needed is about 400 amps. I believe that i have most of what's needed in this one-line diagram. I've highlighted the areas of question for me. if any one can identify any of the highlighted area i will gladly welcome it.
hhasan is offline
Old 05-07-2008, 01:56 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: There's Something Missing
Why are you bothering with a separate main disconnect????
How about using a 3-bank meter main with three 125/100 amp mains? A LOT easier and cheaper. This way all your meters and main disconnects are neatly grouped as well.
All your grounding/bonding goes to this meter main, all the panels are treated as sub-panels.
You also will not have to worry about conductor size between the main and meters.
In my part of NY you would need a lever bypass for the commercial meter section.
Speedy Petey is offline
Old 05-07-2008, 07:39 PM   #3
lbwireman's Avatar
Trade: Engineering, General, Electrical (A,B, C-10)
Send a message via AIM to lbwireman
I agree with Petey. The 3 meter socket bank feeding individual load centers in the 3 seperate occupancies is a much cleaner way to do this installation. There are also some potential code and POCO regulatory issues with having a disconnect "upstream" from the service entry/meters.
lbwireman is offline
Old 05-08-2008, 10:19 AM   #4
hhasan's Avatar
That really clarify things. Thanks guys.
hhasan is offline
Missing "as-built" drawings msnali283 Electrical 16 06-14-2007 05:22 PM
Missing Person skymaster Off Topic (Non Trade) 1 02-04-2007 11:54 AM
Charge to replace missing shingles? gman1966 Roofing 15 05-01-2006 04:02 PM
What am I missing? cruise182 General Discussion 5 09-02-2005 01:04 AM
