Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical > Electrical Picture Post
Old 11-27-2007, 10:49 PM   #1
Electrician
Trade: Electrical Contractor
teddy tennis shoe meter can
I did a service change out today. From 100 to 200 amps. The POCO wanted $1800. to bury a new lateral to a pedestal on the house, so the customer elected to keep the meter on the post 60 feet from the house. He buried the new service entrance wires to the house. Check out the violations in the old meter can. My fairly new apprentice got a good look at how not to do something.
jrclen is offline   Reply With Quote
Old 11-28-2007, 07:38 PM   #2
Thom
thom's Avatar
Ok, I'll bite.
Why did you leave the old posts and plywood backing? Is the new service physically attached? If so, why didn't you prime and paint first.
Our utility will not allow the meter base to be installed on plywood. They require solid lumber or approved siding materials.
thom is offline   Reply With Quote
Old 11-29-2007, 10:28 AM   #3
Electrician
The treated plywood and posts are fine here. The temperature was 15 degrees. Ever prime and paint in 15 degrees? Would you have done it free standing or what?
Old 11-29-2007, 10:59 AM   #4
Thom
thom's Avatar
Since plywood isn't legal here, no, I wouldn't have left it, it would have failed inspection then I would have to re-do it.
If the meter base is approved free standing, it would be fine left alone. If not, I would hav replaced the plywood with solid 2 X ? treated lumber screwed to the posts. It would also be acceptable here to put 2 2X4's across the back then covered (face) with primed and painted siding (t-111) Treated lumber would not require painting, untreated would require prime and painting.
But, that's the local rules. We have some that I think are dumb. On underground service, we are required to strap the lozer to the house. The fact that it is buried 36" into the earth doesn't seem to make it rigid enough. The strap is installed when the service is installed, prior to the installation of the stucco exterior. You end up with an illegal penetration through the stucco in order to have a legal service. Go figure.
Old 11-29-2007, 11:55 AM   #5
Electrician
Interesting. I'm not sure if that pedestal is listed for free standing. It goes down 2 feet. I usually use a single 6x6 treated post or 2x treated lumber as you mentioned with 2 4x4's. In this case, the wood was already there and handy. And it will pass inspection here. But now that you mentioned it, I should have tore off the ratty looking plywood and replaced it with a couple 2x6 pieces like I usually do. A single post wouldn't work with this meter as the back needs to come off for the the POCO connections. I think we must use treated wood here, paint won't comply. I hear you about dumb rules. They are everywhere. And some rules that I think we need, aren't rules.
Meter watching for $$ K2 General Discussion 9 11-10-2007 12:13 AM
Shoe molding in front of Front entry door ? icfbunt Finish Carpentry 18 03-01-2007 08:44 PM
Expansion joints for underground fed meter cans mdshunk NEC Discussion 12 02-02-2007 03:13 PM
Shoe molding ? icfbunt Finish Carpentry 17 12-18-2006 11:36 PM
Moisture meter Richard Painting & Finish Work 10 11-11-2006 08:10 AM
