Trade: Electrical Contractor
Service Entrance Change
Called out on a service call on a rental because the tenants were hearing a arcing sound on windy days and found this old service. Told the owner he needed a new service installed.
Re: Service Entrance Change
This is what it looked like after I did the change. Looks a lot better then the old one.
Union Electrician
Trade: Inside Wireman
Very nice looking in the after pics.
What size was the inside panel? Looks like the house is being fed through a 3/4"? |
The inside panel is 30 Amps with the screw in fuses. The landlord didn't want to change it out at this time.
Looks like a nice job, with the exception of the fact that you used a capped ell. Blech!
Service & Repairs
Trade: Electrician
What's the matter, didn't have much white tape?
#7 | |
Baltimore Electrician
Trade: Electrician
You mean the "pull 90"? (At least thats what we call them)
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
Re: Service Entrance Change |
Trade: Super Electrician
Where is this? It looks like L.A.
Trade: Electrician
you guys are close.... Pomona, Calif.
Electrician
Trade: Electrician
Trade: electrician
Why did you go with the unistrut? Its an eye sour
| The Following User Says Thank You to sparks134 For This Useful Post: | jcalvin (03-26-2010) |
Trade: Mechanical and Electrical
Nice pics man, but whats up with the mc cable?
Service & Repairs
Trade: Electrician
What's a sour eye?
#1 stunner
sore???????
eye sore
220...221...whatever it takes! |
#18 |
Trade: General and Electrical Contractor
Looks good to me. Without the uni-strut how are you suppose to clamp down the riser? That's why they invented paint.
Question I have. I see the old panel was surface mounded and you just moved your new panel over and ran a pipe to the sub-panel inside. I just looked at one today, an old tiny 60 A Zinco combo panel recessed in the wall. Its on a garage wall with access to the back from inside the garage. Small house, 6 or 7 circuits. What I have seen done is someone took the face off the old panel and then surface mounted right over the old panel. I was thinking of doing this, avoids ripping out the old panel, patching stucco etc. But the old panel sticks out about 1/4" past the wall And then there is the issue of the old wires are too short. I know I can put a j-box below it in the wall and then pipe into the new panel. If there wasn't access to the inside of the all I would have to break into it, this kinda defeats the purpose. Has anyone done installed a panel this way? And how did you do it? |
#19 | |
Service & Repairs
Trade: Electrician
Re: Service Entrance ChangeQuote:
You're best off ripping out that old panel and bringing your home runs into a jbox and reroute them into the new service. Ought to be an easy job really. Don't forget to derate those conductors for the branch circuits and your AFCI circuit breakers for the required circuits. Good luck |
| The Following User Says Thank You to Magnettica For This Useful Post: | bauler (03-25-2010) |
#20 | |
| Service Entrance Size | GregS | Electrical Picture Post | 17 | 02-15-2009 08:47 AM |
| Can anyone make any sense out of this? | Teetorbilt | Technology | 24 | 04-16-2007 12:21 PM |
| Service Change? | Liquid Force | Electrical | 3 | 02-28-2007 04:39 PM |
| After service a change, what is best way for temp. connect of power | RandyMc | Electrical | 14 | 10-03-2006 06:58 AM |
| service change code updates?? | marxie | Electrical | 6 | 08-06-2006 11:20 PM |
