Service
Old 06-23-2009, 04:39 PM   #1
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Service
What do you suppose happened here?
All I know about this one is that they had a little renovation/ addition work done about a year, maybe two years ago.
There really is no excuse for having the line side laying on the roof like this.
Magnettica is offline
Old 06-23-2009, 05:28 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Re: Service
They dont bury those thinks in Jesey?
WarnerConstInc. is online now
Old 06-23-2009, 05:31 PM   #3
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Re: Service
I think customer paid for 50' of line, customer got 50' of line.
willworkforbeer is offline
Old 06-23-2009, 05:36 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
Not in this neighborhood they don't, this is in Clark, NJ. Mostly new developments and/ or new houses have the option of going underground but it is very expensive and a PITA sometimes because the EC is responsible for the run out to the transformer. Like with anything, money talks.
Old 06-23-2009, 05:53 PM   #5
woodchuck2
woodchuck2's Avatar
Re: Service
You can see there is a vent through the roof and some kind of stand bolted to the roof so why wouldnt they put a riser up through? I dont know about your location but there is no way an inspector would allow that nor would the grid company hook it up around here. Apparently someone never gave it a thought of the lines rubbing through on the shingles and is that one of the feeds going over the gutter?
I push for underground services around here all the time. No ugly meter on the side of the home, you can install a dis-connect at the pole/pedistal so power can be shut off in an emergency or power can be shut off if there is a problem with the line without having to call the grid company for a dis-connect/reconnect.
woodchuck2 is offline
Old 06-23-2009, 06:41 PM   #6
mrmike's Avatar
Trade: Electrical & Carpentry
Re: Service
That is a Cluster F_-k. Biggest Drip Loop I've ever seen! My guess is the Power Grid Lineman couldn't find his Cable Cutters that day.............
mrmike is offline
Old 06-23-2009, 06:58 PM   #7
Inner10's Avatar
Trade: Control Systems
Re: Service
Well drip loop is necessary....
Inner10 is offline
Old 06-23-2009, 08:11 PM   #8
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
I'll bet building plans changed and the service was already done. I'll also bet that I'll be knocking on the door here to fix it for them.
Old 06-23-2009, 08:55 PM   #9
woodchuck2
woodchuck2's Avatar
Re: Service
That would make a nice job for a day. Definitly a safety risk but at least you will have enough wire on the feed to work with. Who knows what the panel looks like, might be more work there too. Your going to have to replace the wire from the weatherhead down so maybe you can sell a panel upgrade?? Good luck.
Old 06-24-2009, 03:48 PM   #10
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
I would guess by the amount of construction that took place - and by the new PVC riser - that the service has already been upgraded. I doubt the HO's want to pay for another one, but we'll see. Do you think it's weird to have someone knock on your door enquiring about the electrical service?
Old 06-24-2009, 04:09 PM   #11
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
Re: Service
If it's a safety issue, no. I'm no electrician but how would you feel if the house burnt down.
strathd is offline
Old 06-24-2009, 04:38 PM   #12
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
I'd feel bad as I would if any house burnt to the ground and a family was left on the street. There's a part of me that wants to do something about it and there's a part that says to me to mind my own friggin' business. I probably will knock on the door here once the license number arrives from the state in my mail box.
Old 06-24-2009, 04:47 PM   #13
strat hd
strathd's Avatar
Re: Service
Yeah, what do you have to lose ? It would be a good deed.
strathd is offline
Old 06-24-2009, 05:58 PM   #14
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Re: Service
the drip loop does not even drain into the gutter
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 06-24-2009, 10:14 PM   #15
woodchuck2
woodchuck2's Avatar
Re: Service
I wouldnt feel odd about it, its plainly a safety issue and i am sure the owner is unaware of it. I would just tell him you were next door working and saw they have a safety issue and leave them your card. Leave it to them to do the repair. They will either realize the work was done by a hack and look to you for the proper repair or have the same fella come back and do it right. At least you can go home with a clear conscience.
Old 06-24-2009, 10:33 PM   #16
Thom
thom's Avatar
Re: Service
[quote=Magnettica;707046 Mostly new developments and/ or new houses have the option of going underground but it is very expensive and a PITA [/quote]
Out here in backwards and behind-the-times Albuquerque we switched to underground on all new residential about 40 years ago. I'm surprised that New Jersey is that far behind the times.
What amazes me is that people paying for a nice house put up with ****ty looking cable drops.
As for digging the trench, the same trench holds the Gas line, electric service drop, cable tv, and telephone. All are installed by the same crew at one time. The connections for the cables are adjacent to each other and above the buried gas line.
thom is offline
Old 06-28-2009, 08:41 PM   #17
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
These are all from the same house. They have 2 service drops, one on each side of the house.
Old 06-28-2009, 08:51 PM   #18
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Service
Temporary Service from 1961?
Chris
Chris Johnson is offline
Old 06-28-2009, 08:59 PM   #19
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Re: Service
Rental 3 apartment house? Nobody care. Except Magnettica.
Resta is offline
Old 06-28-2009, 11:32 PM   #20
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service
I only care because I'm looking at it as a potential profit maker. This is around the corner from my house and I'm looking to make a little money. What kind of weirdo goes around snapping pictures of crappy services without having an agenda in mind?
Service Magic Yeah I know Frankawitz Online Leads Services 34 12-04-2011 10:31 AM
Lead service providers: Beware! We were FOOLED. Stonewood Online Leads Services 6 01-04-2010 08:41 PM
Google search for a contractor, bathroom Mark Daniels Online Leads Services 7 12-25-2009 12:35 PM
Service Entrance Cable without the service head Magnettica Electrical Picture Post 11 09-01-2008 09:35 AM
Can anyone make any sense out of this? Teetorbilt Technology 24 04-16-2007 12:21 PM
