tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
New 800 Amp Service
Old 04-20-2010, 07:05 PM   #1
paul hardy's Avatar
Trade: electrician
New 800 Amp Service
Installed the service on new house 800 amp single phase still have to complete the grounding and complete the meter it came with duplex lugs for each phase had to order quad lugs.
paul hardy is offline
Old 04-20-2010, 07:57 PM   #2
AustinDB's Avatar
Rewards Points: 592
Re: New 800 Amp Service
it looks real pretty except for the sticker on the top left cover is off center...that's not your fault though :-)
serious question...why the need for an 800A service?
AustinDB is offline
Old 04-20-2010, 08:12 PM   #3
paul hardy's Avatar
Trade: electrician
8000 square foot home with 2000 square foot inlaw suite in basement and a shop below the 3 car garage that has 3 phase moters and a phase converter. no 3 phase power availible from the power company.
Old 04-20-2010, 08:32 PM   #4
Thom
thom's Avatar
Rewards Points: 4,748
I did an 800A residential service 15 years ago, but differently. The POCO had no tri-plex large enough, they wanted 2 @ 400A, side by side.
We installed Two services, one fed the many A/C units, the other fed the many sub panels spaced throughout the 18,000 square foot house.
The natural gas supply was a 5# system in 2" pipe with regulators at various segments throughout the house.
thom is offline
Old 04-20-2010, 09:01 PM   #5
wireless's Avatar
Trade: Electrician
Rewards Points: 316
Top right?
wireless is offline
Old 04-20-2010, 09:55 PM   #6
EES's Avatar
Trade: Working Class
Rewards Points: 75
Did that CT cab come factory with that meter socket attached to the front of it? It looks like it's rivited to it, but I find that odd. Also at 800 amp I am assuming those are 4" pipes, how the hell did you fit expansion joints below that beast and keep those top breakers below 6'7"? I don't even see the tops of the exp joints, so it would seem that they either are not there or those breakers are 8' off the ground.
Edit:That first pic hadn't shown up before I posted this. Hope you didn't pull your wire yet. Cutting an exp joint in there would be pretty easy, unless you pulled your wire already.
EES is offline
Old 04-21-2010, 06:15 AM   #7
AustinDB's Avatar
Rewards Points: 592
Originally Posted by wireless View Post
Top right?
saw top right, typed top left....was a long day
AustinDB is offline
Old 04-21-2010, 08:51 AM   #8
paul hardy's Avatar
Trade: electrician
The conduit is only there to comply with 300.5 around here the power company runs the USE to the meter and they just want protection from below grade to the meter no expansion fittings. The meter is supplied by the power company as you see it the door opens with the meter and the CT's are behind prewired with line and load lugs.
Old 04-21-2010, 01:00 PM   #9
Thom
thom's Avatar
The four mains, are they 200A each?
When I did the 800A service as 2@400A, I had to have the factory custom make the panels. They each had a 3 pole breaker because they didn't make a 2 pole 400A breaker. They then put a single phase guts in, tying into only two of the three poles.
It was a PITA. Charged big $$$ though.
thom is offline
Old 04-21-2010, 02:29 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,688
I've done a few houses in the 15K square foot range but they were all 400A. I'd love to see some pics of that electrical room.
I didn't know you could have a 5# system with regulators in the house.
Inner10 is offline
Old 01-10-2011, 09:42 PM   #11
JBrzoz00's Avatar
Trade: Electrician
Rewards Points: 129
Do you have any more pictures of this setup?
JBrzoz00 is offline
Service Magic Yeah I know Frankawitz Online Leads Services 36 04-21-2012 12:25 AM
Lead service providers: Beware! We were FOOLED. Stonewood Online Leads Services 6 01-04-2010 07:41 PM
Google search for a contractor, bathroom Mark Daniels Online Leads Services 7 12-25-2009 11:35 AM
ungrounded 3 phase 3 wire service JERRYR713 Electrical 7 11-08-2009 07:14 PM
Can anyone make any sense out of this? Teetorbilt Technology 24 04-16-2007 11:21 AM
