Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical > Electrical Picture Post
Old 10-24-2007, 07:54 PM   #1
Trade: electrician Phoenix AZ
My Grandfather left me this....
My Grandfather was an electrician starting in the early 1900's. He passed away in 1986 at the age of 96 and left me this relic from the K&T days.
It still has solder in it.
220/221 is offline   Reply With Quote
Old 10-24-2007, 08:04 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Trade: Plumber
I still use one of those on a regular basis.
KillerToiletSpider is offline   Reply With Quote
Old 10-24-2007, 08:10 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
I was going to say I think you have a lead ladle for cast iron pipe, I have the same one and the kerosene fueled heating pot for it.
mickeyco is offline   Reply With Quote
Old 10-24-2007, 08:21 PM   #4
Ah....that could be as he was also a plumber/general contractor.
Old 10-24-2007, 09:36 PM   #5
Al Smith
did he leave you any caulking irons? or that asbestos rope joint clamp to pour lead into a horizontal cast iron hub?
Last edited by A W Smith; 10-24-2007 at 10:01 PM. Reason: misspelled pour. lets not pout
A W Smith is offline   Reply With Quote
Old 10-24-2007, 09:46 PM   #6
God Bless America
Magnettica's Avatar
Trade: Electrician
I'm not sure I follow as I have never done any soldering.
Did they have to carry one of those around for each splice they had to make?
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is offline   Reply With Quote
Old 10-24-2007, 09:57 PM   #7
Killer--
What is the name of the rope dam thing--I mean the thing you use to dam-up the lead when you pour into the hub.
I think I've still got @15-20 pig of lead --somewhere.
neolitic is offline   Reply With Quote
Old 10-24-2007, 11:33 PM   #8
mickeyco's Avatar
Killer--
The rope with the clamp and chain is called a joint runner, there is also an inside and outside iron for tamping the lead after it's cooled, oakum is the stuff you pack in before the pouring the lead. I've got the hole set but haven't used in over 20 years, but I'm hanging on to it just in case.
Old 10-25-2007, 12:24 AM   #9
I assume that they twisted all their joints and dipped them in the ladel then went back and taped them.
Old 10-25-2007, 12:29 AM   #10
mdshunk's Avatar
That's exactly right. Matter of fact, the guy I apprenticed under still did that on certain jobs. I feel lucky to have observed some of those old-school mehtods. The running taps he used a "soldering copper", which was basicly a chunk of copper on the end of a wooden stick, that was heated in the torch flame for a spell. You can't really dip a running tap.
mdshunk is offline   Reply With Quote
Old 10-25-2007, 03:38 AM   #11
747
747's Avatar
Back in the day plumbers when installing a toliet flange would rap in hemp then pour lead. I think that tool could be used for that. That type of flange has to be carefully chiseled out to replace.
747 is offline   Reply With Quote
Old 10-25-2007, 05:16 PM   #12
I have seen quite a few plumbers using hemp
Old 10-25-2007, 05:33 PM   #13
jmic's Avatar
Killer--
Oakum
Joe
jmic is offline   Reply With Quote
Old 10-25-2007, 05:49 PM   #14
The Grand Wazoo
Trade: Plumber
Actually, it is called a running rope, it is made of of glass reinforced nylon, I have them in all sizes up to 15". A joint runner is the same type tool, but is is made out of rubber with a metal pour gate and clamp on it. Unlike a running rope, a joint runner is size specific, you need a different one for every size pipe, and they don't make them larger than 8".
Old 10-25-2007, 05:50 PM   #15
The Grand Wazoo
Trade: Plumber
We still install them that way.
Old 10-25-2007, 05:52 PM   #16
Teetorbilt's Avatar
I remember all of this quite well. We were still doing it on larger (6"+) iron pipe in the 70's.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 10-25-2007, 05:54 PM   #17
Thanks--trying to remember something like that is almost as bad as having a Barry Manilow song stuck in your head----Almost!
Old 10-26-2007, 01:04 PM   #18
mickeyco's Avatar
Actually, it is called a joint runner, the older ones were made of asbestos, the newer ones are made of some type of rope and you can get them in all types of sizes.
http://www.blackbookoftools.com/Prod...roductID=88727
http://www.fwwebb.com/pdf/2003pasco/pas_c-26.pdf
Old 10-26-2007, 03:06 PM   #19
Professional Remodeler
firemike's Avatar
I also remember using them as a kid helping my grandfather with the cast iron piping. (I rememebr getting bitched at more than once for using sand that was to wet to pack the horizontal joints.) Brought back some great memories...
The one he had for electrical connections was on a swivel so when you moved it up or down to solder the wire, the pot would stay level.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline   Reply With Quote
lol, businessmen, see again - i left out something crucial dirt diggler Business 39 02-24-2007 12:32 AM
One more day left in the before and after contest Nathan General Discussion 8 12-14-2006 05:24 PM
left handed tolls all vinyl Vehicles 15 11-19-2006 07:01 PM
removed border with dif and left streak marks lornmastro Painting & Finish Work 5 08-25-2006 05:21 PM
How many years left in you? ron schenker General Discussion 11 04-07-2006 04:03 PM
