#21 |
Trade: electrician
Re: My Bedroom's Melting Receptacle
yeah in the case of a GFCI you would use both terminals as line and load for it to detect the current difference.
#22 |
Electrician
Trade: Electrical Contractor
Overload? If those conductors are protected by the proper size OCPD and the connections are tight, how would an overload cause that damage? That picture looks like a classic loose connection. And feeding 20 amps through the terminal screws of a 15 or 20 amp receptacle will not cause any problems, that is why the practice is not prohibited by the NEC.
John |
#23 | |
Trade: electrician
Re: My Bedroom's Melting ReceptacleQuote:
There is the possibility of overload, as it was not a heavy duty grade receptacle. It was a cheap 15 amp receptacle on a 20 amp OCPD (was 12 wire though), daisy-chained sharing the entire load of everything (and then some that shouldn't have been on that circuit) down the line. God knows how old the breakers are, who's to say they'd actually trip either - there could have been more than 20 amps flowing through that. In theory the wire is rated for up to 30, but that receptacle is not. Regardless though, problem solved... new wire, quality receptacles and a AFCI breaker |
#24 | |
woodchuck2
#25 | |
Low Voltage Contractor
Trade: C-7
Nothing wrong with daisy chaining them, but the GFCI has to be first in the series in order to protect the other receptacles. -Chilla |
#26 |
Trade: C-7
An important fact espoused by AC/DC(the band not the current)
"Loose wires cause fires Gettin' tangled in my desires, so Screw 'em up and plug 'em in Then switch it on and start all over again I'm gonna get it up Never gonna let it up, no Tickin' like a time bomb, oh yeah Blowin' out the fuse box" -Chilla |
#27 |
electrical contractor
Trade: electrical
1. Pretwisting wires is only as good as the prewisting. I have seen many prewisted connections where the twist is bad & the wirenut is loose. ( Something about the boss did it 50 years ago, big deal). I will put my un prewisted connections againist your prewisted ones! I never said I did 'um loose. Oh, TRY to pretwist stranded!
2. The Code specifically states that all parts of a circuit must be rated for the circuit amps. 3. There is an exception that states that a 15A receptacle may be installed on a 20A circuit. BUT THE RECEPTACLE CAN NOT BE PART OF THE CIRCUIT!!!! Thus NO FAST TAPPING THE PLUGS!! Under the screws counts as fast tapping. Pull 20A through a 15A plug, well IT'S GOING TO MELT! The 15A GFCI's are rated for 20A through them. |
#28 |
Peon
Trade: Sales
You can't overload a receptacle that has the proper wire size and proper sized current protection in place, at least for more than a moment or two.
That problem is likely a loose wire; screw not tight or loosened when the wires were folded back into the box. Either way too loose. Could also be a loose contactor inside the recept that grasps the plug. That would transfer the heat to the screw base. I'm assuming the recept is CU and not AL, like the wires, but can't really see. When I saw the topic I expected to see a recept with the push-in connections. I NEVER use them. I've seen several meltdowns from them and I'd bet they caused many house fires. They shouldn't be allowed. |
#29 | |||
Baltimore Electrician
Trade: Electrician
Also, Quote:
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
| Garage receptacle | ChuckEA | Electrical | 21 | 04-27-2011 07:45 PM |
| 2 designated circuits on one receptacle | K2 | Electrical | 11 | 05-18-2008 08:16 AM |
| GFCI breaker vs GFCI Receptacle | gravtyklz | Electrical | 14 | 10-20-2007 05:33 PM |
| AFCI breaker and GFCI receptacle ? | Bubbles | Electrical | 7 | 10-18-2007 09:40 PM |
| 1st Fixture nuts are melting...any ideas why? | ericjurin | Outdoor Lighting | 3 | 09-02-2007 11:56 PM |
