#41 | |
Service & Repairs
Trade: Electrician
Re: Lookit These Beauties!Quote:
Correct, at least 1/4" of sheating needs to be in the box. (Help! Not sure what code section this one falls under) 2. Wire "nail strips" are plumbing hangers Nothing wrong with notching beams as long as it doesn't interfere with the integritiy of the structure. 300.4 (A)(2) 3. Should have drilled in the center of the studs to run the wire anyway If holes are drilled, an 1 1/4" space from the edge of the stud must be maintained. If not, use a nail plate. 300.4 (A)(1) 4. Runs generally look like crap, and should be WAY straighter and tidy Correct, "workmanlike manner" is reason for a job to not meet code requirements. 110.12 |
#42 |
Service & Repairs
Trade: Electrician
Now there's a hell of a place for a Hot Water Heater!
![]() Primary on this transformer was 4160 volts. |
#43 |
Trade: master electrician USA / France verison
If i am right the primary disconnection is on the right side of transfomer or it was at remote loaction ??
i work on alot of 4160 system so i know how much kick those suckers have. Merci, Marc |
#44 |
Service & Repairs
Trade: Electrician
Im not sure where the disconnect was for this beast.
I do know, however, that it's not energized. |
#45 |
Trade: all
Omg
#46 |
And I do electrical, too!
Nothing like resurrecting a 2-year old thread.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
| The Following User Says Thank You to 480sparky For This Useful Post: | griz (01-25-2010) |
#47 |
Trade: carpenter/ handyman
Re: Lookit These Beauties! |
#48 |
![]() Trade: Welding Contractor
That's just scary...
#49 |
Service & Repairs
Trade: Electrician
I forgot all about this:
![]() Everyone needs hot water! |
#50 |
woodchuck2
Come on now, we know thats your sink and not a customers
#51 |
the pipe master
Trade: plumbing, solar
Out of everything the "stud guards" are the best
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
#52 |
Trade: Solar/Electrical
The homemade hot water heater is awesome. For some reason the guy only had certain materials available and made good. I hope it's not a jail, cause that guy could probably make something dangerous with those cleaning supplies.
#53 |
Must be new to the construction trades??
Very much on par to alot of jobs we've opened up, no suprises, just more BS.
#54 |
Trade: Remodeling contractor
I think this was 3 circuits headed to 1 junction box that was a light fixture
Back in Maine Dubbin' Around Doin' good stuff ...... |
#55 |
Trade: Carpentry / Fencing / Decks
Check out his website now http://markbeiser.com/Site/Home-1.html
It says "you're not finished learning until you're dead". Maybe his wiring caught his house on fire.
www.ParkerFenceandDeck.com |
#56 | |
Service & Repairs
Trade: Electrician
#57 |
Trade: Handyman
#58 |
Trade: Bender Of Nails
Only pros keep the stripped wires in the box.
ML |
#59 |
Full Service Renovations
This post just keeps getting brought back to life!!
#60 |
