Trade: electrician Phoenix AZ
I Went Back To The Service Call From Hell.
Someone asked about the brand name of the panel.
It was Trumbull
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
Moderator
Re: I Went Back To The Service Call From Hell.
Are you sure its not Trubble?
It was trouble all right
![]() No. I looked closely. Definetly Trumbull. The M was funky on one of the logos.
I like the burn marks on the panel cover
Now this may be a dumb question, but what is that panel with all the transformers in it?Dave |
Service & Repairs
Trade: Electrician
Those transformers are for low voltage relay-controlled lighting circuits I believe.
Re: I Went Back To The Service Call From Hell. |
REG EC,CERT EI PLANS EXAM
Trade: electrical
I tink trumbull was a divison of ge in trumbull co ohio near youngstown
#8 | |
7 card stud master
Trade: electrician
Re: I Went Back To The Service Call From Hell.Quote:
I gave him a flat rate thinking I would be in and out, needless to say that was not the case.
"Oh, you hate your job? Why didn't you say so? There's a support group for that. It's called EVERYBODY, and they meet at the bar." -Drew Carey |
Trade: electrical
They were popular Back in the 1950 & 60 s I have worked on ge,touchplate and remcon they came and went along with radiant heat in the celing.
Thanks guys, Aw that sounds like a mess James! Where are you guys from? I see your locations are Pgh and Western PA.
Dave |
7 card stud master
Trade: electrician
west mifflin
Trade: electrical
Butler, but my camps in bedford co near maryland
O ok, I am right in the North Hills area. I have some reletives out in Butler. James you are probley at kennywood everyday
![]() Dave |
7 card stud master
Trade: electrician
Re: I Went Back To The Service Call From Hell. Actually I haven't been there in about ten years. I guess since it's right there the novelty kinda wears off.
Trade: Builder / General Contracting (including Plumbing & Electrical)
yeah I've ripped out some of these before. and the LV crap is exactly that - crap.
I remember 1 of my customers wanted these things fixed and not replaced. said he had it for years and never tripped a breaker. Had bigger burn marks though around the breakers. It also had bad neutral. The plumber figured that out when he went to change the water meter and the arc (load) blew him across the room when he was pulling the pipes apart. Wish I had a camera. Thanx for the pixs. brings back memories! |
Trade: Licensed Master Electrician
Looks like the house probably belonged to an electrician at one time. In my family the GE LV system was used by my Dad and my uncle, while another uncle had the Remcon system. These systems can be nightmares to fix if they have been abortionized like the one pictured. The GE RR7 relays are highly reliable and almost never fail. The Remcons are pretty reliable but do fail occasionally. Remcon is owned by the Amprobe company and new relay replacements are solid state units. All Remcons had their transformers in the relay and the relay was usually mounted at the fixture in the box. The Remcon is a "cheaper" system than the GE, their switches were "flimzy" but nicer looking. Remcons were used in the 60s & 70s, GEs were used from the 50s to present are are of commercial quality where the Remcons were residential. Since the relays are of latching design they only operate momentarily. The only time you smoke a relay is when you have one switch trying to energize the "on" coil, and one switch energizing the "off" coil at the same time and held for several minutes for numerous occurances. These systems were usually only used in high end homes, or in electrician's homes, or in tinkerer's homes.
Trade: Electrical Contractor
i have worked on many homes with touch pad relay system and they are crap . it was not a fab it was for the designer switches
#18 |
Trade: Electrician
I have seen quite a few of these in hi end homes around here built in the 60's.
Love the way they stripped back 3" on the neutrals and soldered them all togeather..Every one I have seen seems to have way to many wires in it for the space provided..mainly because the installaers or repair guys over the years are slobs though. If everyone took a little care and laced up their wires all nice it wouldnt be such a nightmare to troubleshoot. I always try to consider the next guy while doing my work. |
| script to call customers back | Wensdy | Business | 58 | 02-01-2007 09:07 AM |
| Pay Per Call Ads | dougchips | Marketing & Sales | 6 | 10-15-2006 07:48 PM |
| May offer a New Service ?? | tzzzz216 | General Discussion | 15 | 07-16-2006 12:00 PM |
| Should I call for service? | PipeGuy | HVAC | 4 | 01-18-2005 07:29 PM |
