Grnd Or No Grnd
Old 10-08-2007, 10:37 AM   #1
lynn simmons's Avatar
Trade: electrical
Grnd Or No Grnd
i'm installing a service for a friend of mine who's building a strawbale house
the local utility requires a meter socket and disconnect at the pole. the
pole is 100' from the house. i put up a combination disc/can and as required 2 grnd rods and # 4 str. stapled up the pole, this goes to the grnd rods and
the disc. the disconnect is also a small panel where at the bottom of the bus you land the wires going to the house, (200 amp can/disc) my question is a simple one, do i run a grnd to the house along with the feeders? (question of paralleling or the use of neutral + grnd) or set two grnd rods outside the house and, would you put a disconnect on the house or just a main breaker on the panel inside..... thanks for any advice
lynn simmons is offline
Old 10-08-2007, 04:32 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Grnd Or No Grnd
I have to strongly say, if you are doing this for someone else these are things you should know already. Are you an electrician or a GC?
Typically we would not run a ground with the lateral from a pole service to a house.
The disconnect/main breaker panel issue are locally dictated. Does your area require an outside disconnect?
Speedy Petey is offline
Old 10-08-2007, 04:56 PM   #3
mdshunk's Avatar
Re: Grnd Or No Grnd
lynn simmons
Trade: Electrical
Yah...
mdshunk is offline
Old 10-08-2007, 10:39 PM   #4
JamesNLA's Avatar
Trade: Plumbing & Electrical
Re: Grnd Or No Grnd
I was just wondering why this is in the picture post area.....?
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
