Fried Wirenut
I was demoing a kitchen today. When I went to take out the dishwasher this is what I found. Its kinda a bad picture, but the spring inside melted completely through the side of the wirenut. The wires were twisted together with no nicks or any damage and were still tight in the nut when I took it off. I looked at the wire size it was 12ga and was pretty new looking and went directly to a 20 amp breaker.The customer did say that the dishwasher was acting up not to long ago. Any ideas on what would cause something like this?
Re: Fried Wirenut
Only one thing causes that. Wirenut not on tight enough.
Re: Fried Wirenut
Thats the weird thing though, thats the first thing I thought when I saw it but when I untwisted it, it seemed pretty tight. I wish you were closer to Pittsburgh MD I could use a new electrician you deffinetly seem very knowlegable.
Dave |
Re: Fried Wirenut
Trust me, it was loose. The dishwasher has stranded conductors and the romex was solid. It can seem tight on the solid conductor while only holding the stranded dishwasher conductor loosely.
Re: Fried Wirenut
Yup ,I didnt think of that I have seen that before.
Dave |
Re: Fried Wirenut
This brings up the question; What is the best stranded to solid connection beyond soldering? I "tin" stranded wire prior to using wire nuts.
Re: Fried Wirenut |
Trade: Electrician
Re: Fried Wirenut
I actually saw one SHOOT about 30ft across the room one time..Starting up a blower with a loose wirenut in a junction box with no cover...
I gave the guy the ole Ron White(comedian) ...."Well I guess that guy must have been absent on wirenut day"...
Philadelphia electrician
Trade: Electrical contractor
Re: Fried Wirenut
It is important to remember to have the stranded conductor lead the solid conductor in the wirenut, so as to trap the strands with the "plug" of solid copper.
A lot of folks forget to do that. If you start them both off even with each other, the strands wrap around the solid conductor and walk out of the spring. It feels tight, but the stranded wire might as well then just be pushed into the wirenut after it was put on the solid wire by itself.
Philadelphia electrician |
#10 | |
Baltimore Electrician
Trade: Electrician
Re: Fried Wirenut
Good point Robert. I do that, and always tug on the stranded conductor to make sure it is secure.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#11 | |
Trade: electrician Phoenix AZ
Re: Fried WirenutQuote:
....with massive forearms. |
HVAC_NW
Guest
Posts: n/a
Re: Fried Wirenut
Samething happened at my home on wire nuts used for halogen ceiling light in kitchen. That thing was bright. It had a 500W quartz lamp in it.
I got around to changing it with a T8 fluorescent, because I hate incandescent. When I went to remove it, I had to cut the wire, because the wire nut was melted in place. Cause? The fixture was rated for 150W. Previous lady who owned the place before us(or her contractor/handyman) thought it would be a good idea to put a 500W bulb in it. The wires to the ceramic socket got so hot it melted the wire nuts. Unfortunately, the 150W,300W torchiere lamp, 500W work light halogen lamps all have the same form factor and there's nothing to prevent someone from putting in a 500W lamp in place. |
HVAC_NW
Guest
Posts: n/a
Re: Fried Wirenut |
| the august alabama heat fried my dewalt batteries! | shelf guy | General Discussion | 12 | 08-17-2007 11:34 AM |
| Fried | Glasshousebltr | Electrical | 10 | 07-12-2007 05:03 PM |
