Forgive Me Lord For I Have Sinned.
Old 09-18-2008, 08:08 PM   #1
220/221's Avatar
Trade: electrician Phoenix AZ
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 09-18-2008, 08:37 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Forgive Me Lord For I Have Sinned.
New-fangled copper crack pipe????? Whats the deal???
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-18-2008, 08:38 PM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Now you've done it!
Magnettica is offline
Old 09-18-2008, 08:46 PM   #4
Professional Instigator
rbsremodeling's Avatar
looks like he is trying to do some plumbing???
rbsremodeling is offline
Old 09-18-2008, 08:57 PM   #5
Handle It!
I was trying to NOT stir the Us vs (thanks nh for the "term") Them controversy!!
Old 09-18-2008, 08:58 PM   #6
pat c's Avatar
Trade: ELECTRICAL
i think it has something to do with that sawzall blade top right
pat c is offline
Old 09-18-2008, 09:08 PM   #7
220/221's Avatar
220/221 is offline
Old 09-18-2008, 09:11 PM   #8
Ok after closer investigation of the picture
he was trying to run a new pex water line to the house
realize how soft it was and tried to sleeve it with the pvc pipe
hit a rock and drilled through it with the drill bit large enough for the pex pipe, but not the pvc sleeve, gave up and started to run copper instead. got all the way to the house and realized he need a plumber for the inspection, has no water now and his wife is mad.
If only he had called Mike up before he started
Old 09-18-2008, 09:13 PM   #9
Handle It!
He DID use a pipe cutter, or at least attempted to use a pipe cutter, then changed his measurements.....Once or twice....
Old 09-18-2008, 09:16 PM   #10
dkillianjr's Avatar
I'd say driving a grounding rod and couldn't get the last couple inches in cut it a little. If thats the case, that shouldn't hurt. I know a guy that did that once
dkillianjr is offline
Old 09-18-2008, 09:18 PM   #11
No sledge hammer in the picture and the copper looks hollow
Old 09-18-2008, 09:25 PM   #12
pat c's Avatar
Trade: ELECTRICAL
lock-nut looks nice
pat c is offline
Old 09-18-2008, 09:38 PM   #13
220/221's Avatar
Sledge hammer?
Not since 1975 when I discovered power tools.
Heh heh....the "copper" does look hollow though
220/221 is offline
Old 09-18-2008, 09:42 PM   #14
dkillianjr's Avatar
I swear the end towards the camera looks solid with saw marks on it
Old 09-18-2008, 09:49 PM   #15
mattsilkwood's Avatar
Trade: electrician
thats an all out blasphemy aginst the nec. now go to your room and think about what youve done
mattsilkwood is offline
Old 09-18-2008, 09:53 PM   #16
Trade: electrician
i bet you put the ground down too huh
Old 09-18-2008, 09:56 PM   #17
220/221's Avatar
Ok...for the non electricians.
We are required to drive a couple of 8' ground rods in lieu of a ufer ground in the buildings footings. This is necessary in remodel/service change situations.
In some areas, 8' is no big thing. In my area it is OFTEN a serious task. We use a 35 pound demo hammer with an attachment that slips over the solid steel, copper clad ground rod. Even in tough conditions it usually makes short work of it...less than 2 minutes drive time.
In THIS case, it went right thru the asphalt and down to 7' 8" .....then stopped dead. It was in a driveway area so I couldn't leave it sticking up or just pile dirt on it, so .............
220/221 is offline
Old 09-18-2008, 10:02 PM   #18
No big secret my electrician has had to do that on several occasions. Sometimes he drives a couple and says 2 (4's) equal an 8
Old 09-18-2008, 10:15 PM   #19
Trade: electrician
just crackin on ya a little bit ive seen them go 2' and hit bedrock.
Old 09-19-2008, 12:23 AM   #20
mickeyco's Avatar
Trade: Squirrel Handler
Do you happen to have the email address for the electrical inspector in that jurisdiction, I wanted to ask him an unrelated question about something completely different. And if you have any more pictures of that could you post them.
mickeyco is offline
Do we ever forgive and forget? joasis General Discussion 46 03-09-2007 06:03 PM
Why Do Framer's Get No Respect on this Site? JustaFramer General Discussion 133 03-12-2006 11:01 PM
Attention Contractors Home For The Holidays! roofmonkey555 Help Wanted or Looking For Work 20 12-28-2005 07:50 AM
Code Requirements - Fun! Steve Nyhof General Discussion 2 11-17-2005 09:11 AM
