ICF Home
Old 03-21-2007, 07:51 PM   #21
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: ICF Home
I have noticed that everyone that uses ICF's, pour the basement slab before pouring the walls. Why is this ?
rino1494 is offline
Old 03-21-2007, 07:51 PM   #22
joasis's Avatar
Re: ICF Home
Originally Posted by mdshunk View Post
Crazy close side setback. Variance?
Corner lots, 25 wide by 140 deep, total 3 lots 75 frontage...local code is 50 feet from the centerline of the street, 5 feet from the side property line...we have a variance for the other street...42 feet from the front porch....the house is bigger then it looks...2136 sq/ft...tight fit in an older neighborhood.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 03-21-2007, 08:09 PM   #23
mdshunk's Avatar
Re: ICF Home
Originally Posted by joasis View Post
...5 feet from the side property line....
Yeah, that's what I was commenting on. That's tight. Do you have any prescriptive requirements (fire related) due to these tight side setback permissions?
mdshunk is offline
Old 03-21-2007, 08:13 PM   #24
joasis's Avatar
Re: ICF Home
Nope....and believe it or not, some communites like Enid, Oklahoma, have neighborhoods that allow 5 feet between homes. Our code generally makes it 10 feet, but all homes have alley access....of course, most homes are fenced..so going between them is precluded.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 03-21-2007, 08:20 PM   #25
mdshunk's Avatar
Re: ICF Home
Wow. That's almost unheard of for new construction. I surely hope they have some sort of exterior fire resistive rating requirement.
mdshunk is offline
Old 03-21-2007, 08:55 PM   #26
concretemasonry's Avatar
Trade: Masonry consultant
Re: ICF Home
rino -
That is probably so you can pour the wall on the floor slab. It makes it easier to tear off the foam and plug the wall/slab joint with hydraulic cement when it eventually leaks. Usually, preparation and cleanlness of the bottom of the floor inside any forms is poor, leading to a poor bond.
Even at best, you have a cold joint, which is not very good for preventing leakage under pressure. Just hope everyone has a good drain tile system.
Block and conventional poured basements usually have the walls in place before the slab is poured. This gives you additional horizontal resistance against the wall and allows you to get at the wall/slab joint for easy plugging if there is a moisture problem.
Dick
concretemasonry is online now
Old 03-21-2007, 09:54 PM   #27
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Re: ICF Home
We use Logix ICF, good stuff. For you and those in tornado alley this is a home that is not going to have the walls blown out or fence post stuck through the wall.
And the mass of the concrete is going to help with sound proofing.
Wish our frost line allowed for at grade footings. Does your design require a lot of rebar or is that not a required factor.
woodmagman is offline
Old 03-21-2007, 09:58 PM   #28
joasis's Avatar
Re: ICF Home
4 bars of #4 in the footing, which is 24 X 24 inches...#4 bars on 16 inch centers vertically with 1 horizontle bar every course.....still a lot of steel.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 03-21-2007, 10:09 PM   #29
woodmagman's Avatar
Re: ICF Home
It can be a bird cage. We use a 1" vibrator so that it does not get caught up, our design requires a inner and outer row every coarse with a 6" wall design. Have you done many, it is a newer construction method?
Old 03-22-2007, 06:34 AM   #30
joasis's Avatar
Re: ICF Home
I have helped with a few, but this is my first one...I am following the steel layout by the book...I know some guys will run more.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 03-22-2007, 07:28 PM   #31
woodmagman's Avatar
Re: ICF Home
It is amazing the reaction you get from average Joe walking by. They have to come and take a look. An admission fee needs to be imposed.
The biggest thing with these are the forms lifting during the pour and the walls leaning out after the pour. Our solution is to lean the wall in slightly then crank the scaffolding jacks out after the pour, and good old nylon packing tape in the center of every block from top to bottem and on the corners horizontal for about six feet to prevent blow out. The packing tape is a 20 dollar insurance policy that pays thousand in dividends.......
Old 03-22-2007, 07:39 PM   #32
SmithBuilt's Avatar
Trade: Commercial/Residental Construction
Re: ICF Home
I've done 3 homes with icf basements. I pour the wall first then the slab another day. One of my competitors does the wall then the floor right after using a movable scaffold. I don't know yet how they plumb the wall as they pour, but I would like to.
SmithBuilt is offline
Old 03-23-2007, 05:28 AM   #33
UpIACrete's Avatar
Trade: Decorative Concrete
Re: ICF Home
Do they set up their turnbuckles on the outside of the building? We always hammered drilled 2x2 strips of treated on the footing and screwed into the studs, never had one pick up.
"Pride puts perfection into the work."
UpIACrete is offline
Old 03-23-2007, 08:59 AM   #34
SmithBuilt's Avatar
Re: ICF Home
They may set the braces up on the outside. I'm going try to see one of their jobs.
I've always used the supplier's braces and never had a problem. Never had a blowout. I've used Arxx, Logix, and the last was Amnvic forms. An Amnvic plant is close by so I'll probably keep using them, plus they are reversible. You don't have to worry about right or left corners you can just flip them over.
Old 03-23-2007, 09:45 PM   #35
woodmagman's Avatar
Re: ICF Home
It would be great to pour the slab same day, but with the supplied bracing and scaffolds the supports for the brace would be cast in place, unless your supported them on treated blocks that were left in the pour. That would work and you have the pumper and labour there already. I may consider it, never even thought of doing this…
Old 03-28-2007, 07:34 PM   #36
joasis's Avatar
Re: ICF Home
Here is the progress as of 5pm today...we are holding off going higher til the severe waether goes by tomorrow....hoping to pour about tuesday. The steel door frame standing in the middle is the safe room door....tornado country here, so the master closet will be a concrete capped saferoom, 6X11 inside dimensions.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 03-28-2007, 08:37 PM   #37
woodmagman's Avatar
Re: ICF Home
Looks good...Are you going to be using acylic stucco as a finish or somthing else?
Old 03-28-2007, 10:00 PM   #38
AtlanticWBConst's Avatar
Re: ICF Home
J....looks great...thanks for posting this....very informative info...and the pics really make this thread...
Thanks!
- Build Well -
AtlanticWBConst is offline
Old 03-28-2007, 10:05 PM   #39
joasis's Avatar
Re: ICF Home
Brick veneer....11,600 ordered....$329 a thousand from Acme in OKC....
Thanks, Atlantic. I decided to run a few photos of current projects...I'll post on this home til it is down, concrete countertops and stamped patio...all of it.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 03-29-2007, 01:20 AM   #40
747's Avatar
Re: ICF Home
Jo thats a great choice brick veneer. Also nice pics.
747 is offline
Investing in a home ButlerDesigns Business 17 07-13-2007 01:11 PM
Set up at a Home Show Today... Max10 General Discussion 16 10-18-2006 04:03 PM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-15-2006 12:48 AM
Drug caches found in Home Depot vanities HandyAl General Discussion 1 06-14-2006 08:14 PM
