Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Construction Picture Post
Old 06-28-2009, 09:27 AM   #21
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
Can you open up the foam where the red heads are being installed and pack with grout?
I hate seeing something structural span 2 1/2" of foam without a solid backing or connection.
160lbs, is that just clay brick?
Chris
Chris Johnson is offline   Reply With Quote
Old 06-28-2009, 11:27 AM   #22
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
That's pretty interesting Jay. I've always been a wood guy, but it's real nice to have some education on other methods.
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is online now   Reply With Quote
Old 06-28-2009, 03:38 PM   #23
tgeb's Avatar
Originally Posted by Chris Johnson
Remove foam to concrete, 4x6x1/4 angle iron.
What is the local requirement for brick ties there?
A change like that now gets expensive unfortunately.
Originally Posted by joasis View Post
The exposed walls above the porches are less then 8 feet, so it comes down to about 160 pounds vertical load per foot. I don't want to cut the exterior foam, but rather seat the ledger to the wall...probably with redheads, and then brick ties ever 5 course. I have had one bid for 46k labor, and a low bid at $8700....
I have a couple of ideas for this.
1). Studs (2-1/2") welded to the back side of the steel angle, staggered top and bottom. these would end up embedded into the foam and contact the concrete wall when the anchors are tightened.(Drilling the foam out of the path of the stud so it is not compressing the foam.)
This would lock the the steel angle and you would still have most of the insulating value of the foam.
2). A piece of "C" channel iron 2-1/2" X ? with a plate welded to the bottom that projects out to act as a brick ledge. This would be anchor bolted with the channel projecting into the foam and making contact with the concrete wall.
I actually think this would be the stronger option, but more loss of insulating value due to the steel contacting the concrete. You would have to cut through the foam and ties to get it set flush.
What do you think?
www.gebcon.com
tgeb is online now   Reply With Quote
Old 06-28-2009, 04:02 PM   #24
What do you think?
I'd like to see detail pix when
Jo actually does this detail.
What about short (12"?) pieces
of say, 3X6 angle bolted vertically
every 4' as kind of knee braces
under the angle?
You could weld them together
and fill in the foam over the bolted
leg of the vertical angles.
Clear as mud right?
neolitic is offline   Reply With Quote
Old 06-28-2009, 06:46 PM   #25
joasis's Avatar
The actual method I am going to use will be to use steel sleeves, 1/2 inch wall, with a 5/8 bore and 2-1/2 inches long. Drill for the 5/8 red head, which is a 9 inches, then cut out the circle for the sleeve, install the bolt. Then when the red head is tightened after the lintel is on, the sleeve acts like a washer back to the wall. Easy, quick, and simple. 3 or 4 feet on center, these will hold up 20 times more load then the brick, which will be queen size, 5 and 20 lbs to the sq/ft, 7 feet high, 300 lbs. per bolt give or take.
Great ideas, but I am not cutting out the foam to direct set the lintel. It would work, but what a pain.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is offline   Reply With Quote
Old 06-28-2009, 07:13 PM   #26
tgeb's Avatar
I had considered a sleeve as well but thought the studded angle might be better/easier, but then I have never worked with the ICF systems.
I did get a sample block a few weeks ago though, and have been pushing it to the builders I work with.
www.gebcon.com
Old 06-28-2009, 07:42 PM   #27
Bunny by Malco - NY
I would consider welding a 1/2" plate every couple of feet to the back of the angle to create positive contact to the concrete wall, it will require a notch thru the foam but will help elimate any possible sheer from the weight.
I realize the bolt can handle the load, but I always get concerned when it is cantilevered.
I could also just be nervous because of where I live as well!!!
Chris
Old 06-28-2009, 07:59 PM   #28
Yeah, back here the ground
doesn't move so much,
but once in a while the sky
will come and get you!
Old 06-28-2009, 09:41 PM   #29
joasis's Avatar
I told you Tom, I would come up and give a few lessons!
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Old 07-07-2009, 10:42 PM   #30
Trade: general contractor
So..how much would a house like that cost in Bristow, Ok.?
mics_54 is offline   Reply With Quote
Old 07-08-2009, 06:03 AM   #31
joasis's Avatar
It will finish for less then 300k.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Old 07-08-2009, 01:10 PM   #32
I was looking for more of a $/sqft number. Just trying to figure out the market there. I may have to move back to that area to help out my aging folks for a while. I was looking at some job ads and labor seems very low. I probably wont be building homes but I thought the average sqft figues would give me a better idea as to the job market than ads for trade employees.
Old 07-08-2009, 07:41 PM   #33
joasis's Avatar
New home costs, meaning true cost, is running less then $70. This house is far from typical, and when viewed from the "enclosed space" aspect, and then at interior framing, it is holding less then 60 on about 5800 total feet.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
The Following User Says Thank You to joasis For This Useful Post:
mics_54 (07-08-2009)
Old 07-08-2009, 07:54 PM   #34
OGStilts's Avatar
I'm jealous, I've been wanting to do one of these for a couple of years.
OGStilts is offline   Reply With Quote
Old 07-08-2009, 07:58 PM   #35
I'll be waiting for some pictures of the finished house. I've used alot of ICF for foundation/crawls up here. but with concrete at 130 a yard it isnt very popular for much more in the residential market. Last I crunched the numbers new home construction was pushing $150/sqft.
Old 07-11-2009, 07:45 PM   #36
joasis's Avatar
Here are pictures from Friday:
icf-custom-home-bristow-oklahoma-bristow3-00603.jpg   icf-custom-home-bristow-oklahoma-bristow3-00704.jpg   icf-custom-home-bristow-oklahoma-bristow3-02405.jpg
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Old 07-11-2009, 07:49 PM   #37
joasis's Avatar
A few more....plumbing and electrical
icf-custom-home-bristow-oklahoma-bristow3-00906.jpg   icf-custom-home-bristow-oklahoma-bristow3-01008.jpg   icf-custom-home-bristow-oklahoma-bristow3-01307.jpg
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Old 07-11-2009, 07:51 PM   #38
Excellent! I like the metal roof.
Old 07-11-2009, 07:59 PM   #39
joasis's Avatar
A few more views. The first is what the foil back looks like under the steel roof. For those interested, the homeowner took a thermometer up on the 3rd floor, where this view was taken, and measured the temp at 86 degrees, it was 105+ outside. Yes, there is a lot of ventilation through the house right now, but the lower temperatures we see are typical in ventilated attics when we install this under a steel roof. Takes a load off of AC.
The last picture shows the outdoor living area, framed in 6x6 rough western cedar. The concrete was dyed and an antique release in charcoal, Roman slate rolled.
icf-custom-home-bristow-oklahoma-bristow3-01711.jpg   icf-custom-home-bristow-oklahoma-bristow3-01110.jpg   icf-custom-home-bristow-oklahoma-bristow3-02309.jpg
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Old 07-11-2009, 08:07 PM   #40
will the room in the attic be living space (heated and cooled)? If so I assume you will insulate the roof at the rafters with rigid foam between the rafters with a space behind it for air flow.
Home Depot...WTF? ChainsawCharlie General Discussion 46 07-06-2009 07:58 AM
our first home show of 2009.... handyhands Marketing & Sales 23 02-04-2009 12:23 AM
Anybody heard anything about Home Depot getting out of the installation business????? Mike Finley General Discussion 35 02-02-2009 07:28 PM
Custom Home Building wackman Business 2 03-16-2007 04:08 PM
Custom Home Contract sample Shawnkt Business 7 07-11-2006 04:16 PM
