The great cornholio
Trade: Framing/ICF
I Didnt Know Where To Put It So..
This is for a shed that I will heat in the winter. The foam would be against the bottom of the sheathing. If I build a floor frame and insulate with foam and sheet it with 3/4 inch plywood will I have a moisture problem between sheeting and the foam? Will I have the same problem with vapor barrier and insulation in the walls? .
would I need to vent the floor ? |
