Elevated Bluestone Deck Causing Staining On Stucco
Old 08-25-2010, 11:07 AM   #1
mike2010's Avatar
Trade: Construction
Hi all
we have an elevated bluestone deck that is causing staining on the stucco at the front of the deck. The staining is obviously coming from under the bluestone, and not as a result of water run-off.
We'd be interested to hear if anyone has dealt with this before, how, and how succesful it was.
Does anyone have any ideas as to a) what is causing it, and b) how to prevent this, other than sealing the deck?
thanks
Mike
Elevated Bluestone deck causing staining on stucco-img_2759.jpg   Elevated Bluestone deck causing staining on stucco-img_2763.jpg
mike2010 is offline
Old 08-26-2010, 12:51 PM   #2
gilster's Avatar
Re: Elevated Bluestone Deck Causing Staining On Stucco
I have a client with a slate covered patio with the exact same problem.
Also interested in the cause.
gilster is offline
Old 09-02-2010, 10:26 AM   #3
Diamond D.'s Avatar
Trade: masonry/hardscaping
Hey Mods, looks like two with one blow here!
" ROCK YOUR WORLD "
Diamond D. is offline
Old 09-03-2010, 12:14 AM   #4
Rockmonster's Avatar
Trade: Masonry
That looks to me like concrete pavers as opposed to bluestone....but my guess is that the stain is caused by that angle iron bleeding rust onto that wall....At least that looks like an angle iron to me from here.....Sure Klean makes a Ferrous sp? cleaner that can be fairly effective....I've heard of guys using a poultice on tough stains as well....I do know these can be tough to remove, some guys just want to use muriatic, although in some cases this has been found to be the culprit. But you do have to remove the source, and unless I'm way off, at least it won't be the "bluestone"....good luck!
Rockmonster is online now
Old 09-05-2010, 12:25 AM   #5
rotarex's Avatar
its just the way the OP presented it gave it away
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Deck Staining treatment? dodge07around Decks & Fencing 2 07-15-2010 09:16 PM
elevated wood frame deck with EP Henery pavers in it. mike stanislaw Decks & Fencing 15 07-03-2009 05:59 PM
Deck Staining Methods? JMG1959 Painting & Finish Work 11 02-22-2007 12:07 PM
deck staining over penifin wallyofthenorth Painting & Finish Work 3 07-06-2006 09:57 PM
Water staining on exterior stucco cutnroller Painting & Finish Work 13 03-17-2006 05:22 PM
