Trade: Construction
Deck Works
In the grand scheme of things, this deck is straightforward, except it took a while to straighten out the comedy...short story: original deck idea was to be 13ft off front of house, but after much useless legwork (plans/material lists etc.), it turns out cottage is 5ft off property line, and code around here states any structure attached to house must be 5ft off property line...oops. So, there is a code workaround...if deck is not physically attached to house, then deck can go right to property line, provided it isn't more than two feet off ground...
After screwing around for six months, the deck expands to 1000sqft (wraparound) and 21 footings. Below is before, excavating, footing work, concrete...more to come. |
Trade: Construction
Re: Deck Works
Concrete poured....
Trade: Construction
Re: Deck Works
You'll note some of the columns are square and others using sonotubes...it is wet here, and the shorter columns are easier using wood and I don't have to worry about them getting wet...plus, nobody will see the square columns...the large pad is for future hot tub...
Trade: interior remodeling
Re: Deck Works
You have some serious footings on that one. Looks like a life time strong deck,I'd hire you.
Neat work,very clean.---Mike-- |
Trade: GC/ Peace Keeper/#1 Financial Burden Carrier
Re: Deck Works
Yeah, nice work...please be sure to follow up with finished photos. ...And look at that country side! Beautiful. Lucky you, you get to work in those surroundings....I can almost smell the fresh air!
I hope I'm not as dumb tomorrow as I am today, thank God I'm smarter today than I was yesterday!!...wait, I just said that.
Trade: Carpentry / Fencing / Decks
Re: Deck Works
Keep us posted, I'd love to see it when completed. Looking good so far.
www.ParkerFenceandDeck.com |
| The Following User Says Thank You to curapa For This Useful Post: | Mellissam (03-16-2010) |
Trade: Construction
Re: Deck Works
Thanks for the words...the beams have been installed...onto the joists...usually a relaxing aspect of a deck job, but since this deck wraps around three corners and numerous nooks (and framing a hottub), it is going to be a pain. I discovered a quick and easy way to lay joists, should you be interested (works best on rectangular/square decks). I cut up a wack of blocking on my mitre saw using end cuts of beams and WHY. Given they are all perfectly the same, I use them to measure...no longer do any measuring when laying out joists...makes for mindless entertainment and production is blazingly fast. Also, I've noticed blocking over beams reduces twang on deck...not to mention the blueskin I put on the beams (physically barrier mostly from crud cooking on top of the beams).
Trade: siding
Re: Deck Works
hhhmmm reduces twang you say?..... very nice
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | Mellissam (03-16-2010) |
Trade: Construction
Re: Deck Works
Slowly getting the joists done...the back corner was a headache trying to get balance as I turned the corner, and maintain good spacing for the railing....a little overkill on the blocking, but I've never had anyone complain after-the-fact. Cheers, Melli
Re: Deck Works
What type of material is it you're covering the beams with?
Trade: Construction
Re: Deck Works
Blueskin..used for window/door sills and WHY. I used to use 6mil vapour barrier, but for the price blueskin isn't out of line. The sole purpose is to protect the top of the beam from becoming a soup kitchen. And there is the vibration damping effect too...
| The Following User Says Thank You to Mellissam For This Useful Post: | Girlscanbld2 (03-09-2010) |
Trade: Construction
Re: Deck Works
Maybe the deck boards will be kinder to my back....to old for this....LOL
Mod / ArchiBuilder
Re: Deck Works
Is that a residence? How big?
Great work, by the way.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
| The Following User Says Thank You to Cole For This Useful Post: | Mellissam (03-09-2010) |
WICKED WOODCHUCKER
Trade: RESIDENTIAL CONTRUCTION, BUILDING & PROPERT MAINT.
Re: Deck Works
nice work, i wish i had a big deck like this right now!
| The Following User Says Thank You to mnjconstruction For This Useful Post: | Mellissam (03-09-2010) |
Trade: Construction
Re: Deck Works |
Trade: Construction
Re: Deck Works
Curious w/ your double rim joist and fascia, how do you attach your handrail posts? outside of fascia?
(Like seeing the blueskin on the beam tops - good protection.) Mac |
| The Following User Says Thank You to BuiltByMAC For This Useful Post: | Mellissam (03-09-2010) |
Re: Deck Works
Nice!!
| The Following User Says Thank You to Girlscanbld2 For This Useful Post: | Mellissam (03-09-2010) |
#18 |
Trade: Construction
Re: Deck Works
Outside of fascia. I use 5/8" carriage bolts 8" long right through the works (rim joist and fascia)...I've found 5/8" bolts don't flex like 1/2" bolts. I also use a big honkin washer on the bolt to spread out the point stress...I've posted a few pics of this on other threads. Hmm, gave me a thought about installing posts on the inside..would lose a little deck space in the process and be a pain to work the deck boards around the post...clean look though. I think I've seen your work like that...or was it Al posts...
Thanks, cheers. |
#19 |
Mod / ArchiBuilder
Re: Deck Works
Any Updates?
#20 |
Trade: Construction
Re: Deck Works
Rain, then rain....oops, raining again. I need dry weather to get the boards on...so, it'll take a few days before i get the deck on...hate posting pics of half-finished job....lol
| new tigerwood deck -- boards with fuzz, green-yellow tint? | andywocky | Decks & Fencing | 32 | 08-20-2009 04:10 AM |
| Can I cantilever an extension to an existing deck? | lot249 | Carpentry | 9 | 05-23-2009 01:27 PM |
| Dry Joist deck system | ProHab | Decks & Fencing | 6 | 05-08-2009 09:05 AM |
| DECK question ???? | davinci | Decks & Fencing | 9 | 10-30-2008 07:02 PM |
| 2 storey deck on top of flat roof | woodworkbykirk | Decks & Fencing | 5 | 10-27-2008 09:59 AM |
