#21 | |
Re: Poorly Framed HomesQuote:
Good catch. I like all the kickers of the roof ply.
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 09-10-2009 at 05:38 AM. |
#22 | |
The frame and the foundation are an obvious mismatch. (Former Bonehead Builder Changes ?) It sound like the original architects plan should be built on that foundation or it should be totally scraped. I would like to see an engineer OK your new design proposals. Let us know how that works out for you. "Meanwhile, out behind the outhouse, things're piling up." |
#23 |
I used to think so.......
My best friend designed this home. The builder was adamant for a more "cut-up" roof line without any change to the floor plan ?????
So, to make him happy, the hip/valley to nowhere was invented. "gag"
#24 |
This was the first and only time I have ever seen tails sloped down.
I have done plenty split pitch roof systems i.e. 8:12 / 12:12 where the 12:12 rafters are bob tailed (no tail) and then 8:12 tails are added beside each rafter. This was in Memphis (Germantown) Tennessee. I had to turn around out of disbelief and a morbid curiosity to photograph rough framing. It looks to me, like the brick frieze is down in the window RO........but that could be the way they wanted it |
#25 |
I can't picture that looking good, and nice staging
#26 |
Trade: Siding and cornice carpenter, light remodeling.
Re: Poorly Framed Homes |
| The Following User Says Thank You to jfman For This Useful Post: | Winchester (11-21-2010) |
#27 |
Trade: Renovations cabinetry
Here, in Ontario, Canada, we have flagged areas in the construction process that MUST be inspected by the city engineers. Footings at load bearing points is a really BIG one! Until the load bearing footings are signed off by the inspector, load bearing walls and posts have to wait! Additionally, the building plans are scrutinized by the city engineers, to ensure the processes follow the Ontario Building Code minimum regulations. OH..we still have fly-by-night outfits that turn out trashy, dangerous projects as those shown, but guys don't last much past the court case, the fines, or in severe cases, imprisonment!! An established minimum building code, with defined inspection points, by certified independent engineers would go a long way to reduce these disasters.
-T.J. - |
#28 | |
Trade: carpenter/ handyman
I bet that the roofers didn't get paid nearly enough for this job? It looks like they used only 20 yr shingles too.
Steve Quote:
#29 |
Trade: General contractor
Wow that is ridiculous..
#30 | |
Trade: Finishing Carpenter
Buts thats not exactly the proper fix to say the least. |
#31 | |
The great cornholio
Trade: Framing/ICF
#32 | |
The great cornholio
Trade: Framing/ICF
oh both of them, the hip is out of place because there is no jog |
#33 |
LET ME SHOW YA SOMETHIN!!
Trade: I do that too!
If I remember correctly the truss company we order our trusses from are stamped by an engineer before they leave the factory.
DO IT!! DO IT!! DO IT!! |
#34 | |
Framer-billy
In that last pic, I see a sheet of OSB upside down..
#35 |
Trade: Custom Homebuilder
#36 | |
Trade: Carpenter/gc
#37 |
Trade: Exterior Remodeling
I also see a sheet of the fiber board upside down, did not think anyone even used that anymore. how is in the world is that going to work , don't they know the print has to be up so you can read it.
| The Following User Says Thank You to Randy Bush For This Useful Post: | Dirtywhiteboy (06-20-2011) |
#38 | |
CleanFramer
| Mobile Homes | SunSet | Pressure Washing | 5 | 05-20-2009 01:34 AM |
| The House of Tomorrow from the Recession Today | NC2X4 | General Discussion | 11 | 02-28-2009 05:05 PM |
| HELP!!! - Poorly Framed Wall | Nailbird | Construction | 25 | 12-14-2008 03:35 PM |
| Steel framed wall to Stick Framed Wall | Agolk2 | Construction | 2 | 09-07-2008 04:50 PM |
| Developer bankrupt but we have homes there | fishorski | Construction | 8 | 08-26-2008 10:06 PM |
