Logcabin-Corner 6x6 Timber Stairs
Old 11-23-2008, 11:01 PM   #21
basswood's Avatar
Trade: trim carpenter
Re: Logcabin-Corner 6x6 Timber Stairs
Originally Posted by mickeyco View Post
Did you play with Lincoln Logs when you were a kid?
I did.
This is my first real world use of all that practice with the Lincoln Logs.
basswood is online now
Old 11-29-2008, 07:54 PM   #22
basswood's Avatar
Here are the stairs with the 6x treads housed in a second inverted stringer.
Most treads just need to be held up, these also have to hold the earth back, thus the inverted top stringer. I've cut lots of stringers, but this one going over the top, confused the heck out of me... had to draw it out three times.
Given the variable dimensions of the 6x, the first cutting was not the best fit. I scribed several of the riser cuts for a better fit... may be a moot point since the 6x's are likely to shrink some and open gaps up (maybe pressure and moisture from the dirt will keep the joints tight).
Cheers,
Bass
How much to charge for new stairs skarrlette Finish Carpentry 40 12-14-2010 05:38 PM
Chair rail down the stairs and around a corner? homeowner Finish Carpentry 19 11-05-2009 06:41 PM
Corner to Corner slump Blockade Demolition 2 12-02-2008 02:41 PM
Deck with stairs at 45 degrees at corner Dad'll do it Decks & Fencing 12 04-22-2008 09:49 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
