Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Carpentry Picture Post
Old 11-23-2008, 08:32 PM   #1
basswood's Avatar
Trade: trim carpenter
Logcabin-Corner 6x6 Timber Stairs
Finished the outside stairs to my basement this weekend. The approach I chose uses interlocking 6x stock as both retaining wall and stairs.
logcabin-corner-6x6-timber-stairs-basement-timber-stairs.jpg   logcabin-corner-6x6-timber-stairs-logcabin-timber-stairs.jpg
basswood is offline   Reply With Quote
Old 11-23-2008, 08:39 PM   #2
genecarp's Avatar
Full 6'' rise?. What goes on top to create a full step width? G
genecarp is offline   Reply With Quote
Old 11-23-2008, 08:42 PM   #3
basswood's Avatar
I'll back fill with rock for drainage and then use a treated 2x10 as a finished tread for a total rise of 7".
Old 11-23-2008, 08:49 PM   #4
genecarp's Avatar
Is that a stringer i see on the foundation side ? And the retaining wall side goes through the wall fully ? It looks pretty cool. what is the staining i see as the step passes through the wall. G
Old 11-23-2008, 08:49 PM   #5
curapa's Avatar
Trade: carpentry / fencing / decks
That looks like a pretty cool project but when you add your 2x10"s isnt the rise going to stay 5 1/2", unless i'm missing something?
www.ParkerFenceandDeck.com
curapa is online now   Reply With Quote
Old 11-23-2008, 08:53 PM   #6
genecarp's Avatar
Originally Posted by curapa View Post
that looks like a pretty cool project but when you add your 2x10"s isnt the rise going to stay 5 1/2", unless i'm missing something?
7 1/2''
Old 11-23-2008, 08:55 PM   #7
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Look on the stringer side you can see what appears to be a 1 1/2" piece of riser stick up past the 6x6. The green stuff is a chemical treatment applied to cut ends.
WarnerConstInc. is online now   Reply With Quote
Old 11-23-2008, 08:59 PM   #8
curapa's Avatar
Originally Posted by genecarp View Post
7 1/2''
In the first pic the 6x6's appear to be lined right up with one another, if you were to put 2x10's on them it would not make a difference on the rise of each step.
Old 11-23-2008, 09:12 PM   #9
curapa's Avatar
The rise in the second pic looks inconsistant. Towards the top I see a bit of stringer and the lower it goes it appears the stringer gets bigger. The bottom tread looks like its an extra 5 1/2" wide.
Old 11-23-2008, 09:33 PM   #10
basswood's Avatar
Yes there is a stringer on the foundation side, and I am going to add another inverted stringer, above the stairs (the two stringers will sandwich the stairs on the foundation side). The inverted top stringer will counteract pressure from soil.
The 6x treads and the retaining wall timbers are both notched for half-lap style joints.
The staining is the "re-treatment" of all cut ends and notches (Cuprinol).
Old 11-23-2008, 09:49 PM   #11
basswood's Avatar
You are correct, I misspoke.
Old 11-23-2008, 09:51 PM   #12
basswood's Avatar
It only appears that way...photo angle.
Old 11-23-2008, 09:59 PM   #13
Good ol' Cuprinol #10.
Get it on your hands, and you
can taste it with your dinner.
Anything that foul must
be good!
neolitic is online now   Reply With Quote
Old 11-23-2008, 10:00 PM   #14
Trade: GC/Remodeling
I see this will 'spread the load' of the soil, as long as the treads are attached to both stringers. Around here, our clay would push those treads in and crack the foundation in one season.
Really cool way to maintain drainage... I like it
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 11-23-2008, 10:04 PM   #15
genecarp's Avatar
Nice stuff Bass, thanks for showing it.
Old 11-23-2008, 10:06 PM   #16
Looks like he's got deadmen
to prevent that.
Old 11-23-2008, 10:17 PM   #17
to prevent that.
uhhhhh oops... I missed that. Verrra Nice
Old 11-23-2008, 10:33 PM   #18
mickeyco's Avatar
Trade: Squirrel Handler
Did you play with Lincoln Logs when you were a kid?
mickeyco is offline   Reply With Quote
Old 11-23-2008, 10:56 PM   #19
basswood's Avatar
Glad you like it.
The old steps were steep and narrow, concrete. The new stairs will be an improvement. I went with wood, because wood is what I know.
Old 11-23-2008, 10:58 PM   #20
basswood's Avatar
to prevent that.
That was the plan, anyways.
Chair rail down the stairs and around a corner? homeowner Finish Carpentry 19 11-05-2009 06:41 PM
How much to charge for new stairs skarrlette Finish Carpentry 39 01-05-2009 09:50 PM
Corner to Corner slump Blockade Demolition 2 12-02-2008 02:41 PM
Deck with stairs at 45 degrees at corner Dad'll do it Decks & Fencing 12 04-22-2008 08:49 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 12:59 PM
