Contemporary Table.
Old 12-06-2017, 08:31 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 4,344
Contemporary Table.
Had a client show me this pic:
A table that they would like me to build. But.... They want the top to be brushed aluminum (laminate) and the bottom to be wood. The wood will be stained black.
The bottom of the base are two 1 5/16" thick boards glued together.
One has a 51 angle and the other has a 39 angle on it.
The uprights of the legs are three 1 5/16" thick boards glued together.
I cut the boards on the bandsaw to get the curve on it. I pre-cut the angles on the blanks before I cut the curves on them so I wouldn't have to fight with the angle.
For the test assemble, I used two 3" screws so I could figure out the angle of the X so I can dado a half lap so they are flush with each other, but that's not until tomorrow.
After sanding a slight curve on the angle section of the upright to get rid of the part that hung over and give it a nice blended look, I screwed it off. This is the leg set that splays in.
Here is the leg set that splays out.
And to find the correct angle the two of them needed to have to form the X and show up proper for the overhang I cut a pc of cardboard the size of the tabletop. I'll draw lines on the intersection and cut that area out with a dado blade so they are half lapped and flush with each other.
Very interesting interaction with the legs as you walk around the table.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
The Following 8 Users Say Thank You to Leo G For This Useful Post:
AustinDB (12-14-2017), Defenestrate (12-06-2017), Golden view (12-06-2017), goneelkn (12-07-2017), greg24k (12-07-2017), onmywayup (12-09-2017), overanalyze (12-07-2017), Rio (12-08-2017)
Old 12-06-2017, 08:39 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,257
Re: Contemporary Table.
Cool.
You curved the legs, which are different from the original. Why and who's idea?
How did you strengthen the bottom joints?
MarkJames is offline
Old 12-06-2017, 08:45 PM   #3
LRG WoodCrafting
Leo G's Avatar
It was the clients idea for the curve.
Right now the joints are just temporarily screwed with two 3" deck screws. It's White Oak, so just those screws are very strong by themselves. Eventually I'll be using West System Epoxy to glue the joint. That's all it will need. The top of the legs will be screwed to a pc of particle board which will nest inside the laminate top.
Carpenter by day.
http://lrgwood.com
Leo G is offline
MarkJames (12-06-2017)
Old 12-07-2017, 03:39 PM   #4
LRG WoodCrafting
Leo G's Avatar
Milled up the half lap, 31.5 for the dado angle. Used a sled with an angled fence to cut the dadoes.
Fits nice
Used West System Epoxy and 2 screws to put the legs onto the base. You can still see the epoxy, it's wet. It'll get sanded off.
Top view is interesting. It won't be seen When the table is on it.
After the epoxy cures I'll cut the top angles. The base will go against the tablesaw fence which will be set at 34 1/2". Then I'll just push it through and it'll make a parallel cut to the base which will be the perfect angle for the particle board to sit on flush.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-07-2017, 05:13 PM   #5
jstanton's Avatar
Trade: carpentry
Rewards Points: 212
Any idea on hours? Almost should have made 2, I'm sure family or friends is going to want one too. Great job & fun project.
jstanton is offline
Old 12-07-2017, 05:19 PM   #6
LRG WoodCrafting
Leo G's Avatar
Hours aren't that bad, running around time makes it longer. My bandsaw is just a little bench bandsaw, I had to go to a buddies 1/2 hour away to use his to cut the 3 3/4" wide curved legs. Probably have a total of 20-25 hours in it by the time it's completed.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-08-2017, 03:08 PM   #7
LRG WoodCrafting
Leo G's Avatar
Stained them black and put the 1st coat of clear on. I threw in a bit of black dye for the first coat. Hope it's not to black.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-12-2017, 09:42 PM   #8
LRG WoodCrafting
Leo G's Avatar
Carpenter by day.
http://lrgwood.com
Leo G is offline
The Following 3 Users Say Thank You to Leo G For This Useful Post:
KAP (12-13-2017), overanalyze (12-12-2017), slowsol (12-12-2017)
Old 12-12-2017, 10:08 PM   #9
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Thanks for sharing the pictures. Cool to see the process.
DiaperRiot is offline
Old 12-12-2017, 10:28 PM   #10
LRG WoodCrafting
Leo G's Avatar
Just waiting for the countertop place to call to let me know the brushed aluminum top is completed.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-14-2017, 12:02 PM   #11
LRG WoodCrafting
Leo G's Avatar
Picked up the top today. Put a support on top of the legs and put the table on the legs. Looks nice. And it's stable. I always worry about stability of a table that doesn't have 4 legs in each corner.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-14-2017, 05:18 PM   #12
LRG WoodCrafting
Leo G's Avatar
And here it is installed ready for use. By the time I was leaving they had clients using the table.
Carpenter by day.
http://lrgwood.com
Leo G is offline
The Following 2 Users Say Thank You to Leo G For This Useful Post:
hdavis (12-14-2017), Xtrememtnbiker (12-14-2017)
Old 12-14-2017, 05:49 PM   #13
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,248
16 legs is overkill...I think.
Looks nice Leo.
Democrats are doing more to undermine our country than Russians could ever hope to do.
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
hdavis (12-14-2017), Tinstaafl (12-15-2017)
Old 12-14-2017, 10:36 PM   #14
LRG WoodCrafting
Leo G's Avatar
Just in the sprayroom for the lighting.
Carpenter by day.
http://lrgwood.com
Leo G is offline
New shop (table saw table) rservices General Discussion 9 06-12-2017 11:53 AM
Broke the Tapco cut table out after 3 years. VinylHanger Tools & Equipment 4 05-26-2012 01:00 AM
Mft3 extension table mod BCConstruction Tools & Equipment 11 03-27-2012 08:41 PM
router table plans platinumLLC Tools & Equipment 2 04-29-2009 08:14 AM
parts for dial n angle tapco saw table LMS CONST. Tools & Equipment 0 10-27-2008 10:36 PM
