Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Carpentry Picture Post
Old 09-28-2009, 09:51 PM   #1
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
....Clipboard Shelf
Forum seems slow so I will post this. Its a slam bang job...everything is just getting edge banded with veneer.... Used a router to plow the base and then just doubled up the back and cut little pieces on the 45 to create the "vertical" dados. I didn't want to bother with the table saw and a dado blade...
This was a test...but shows how it works and that I needed to add 1/2" to the dado length...
TBFGhost is online now   Reply With Quote
Old 09-28-2009, 11:15 PM   #2
Lots of clip boards.
For a doctor's office?
neolitic is offline   Reply With Quote
Old 09-29-2009, 09:48 AM   #3
Faking my Way
TBFGhost's Avatar
real estate broker....
Old 09-29-2009, 02:59 PM   #4
Faking my Way
TBFGhost's Avatar
Stained
Old 09-29-2009, 07:50 PM   #5
dkillianjr's Avatar
Looks good tbf
"Pay now or Pay later"
dkillianjr is offline   Reply With Quote
Old 09-29-2009, 08:36 PM   #6
little fish
world llc's Avatar
Trade: general contractor
are thoes 45's veneered over in 1 piece, or 3 seperate pieces?
looks too nice to be holding clip boards....
www.worldllc.net
world llc is offline   Reply With Quote
Old 09-29-2009, 08:47 PM   #7
Faking my Way
TBFGhost's Avatar
Not sure what your asking Matt, but I plowed the dados in the bottom with a trim router and a jig. Single layer of 1/2" Cherry.
The back is made up of two layers of 1/2" Cherry. The vertical 45* are applied the back layer. I used a stop block on the miter saw and cut 2 and some odd inch peices over and over again with 45* miters and applied them with glue and pins from the back. For the sake of $$$$$$$, I ripped the veneer off the scraps and re glued that back on the edges....kinda out of the way, but it worked.
On a side note, I put the price of a new Dado blade in the job....didn't need it so looks like I got me a free dado....if you want to look at it from that angle...lol
Thanks for the props guys....I am still in awe of so much of the work I see on here.
Old 09-29-2009, 08:53 PM   #8
little fish
world llc's Avatar
is it solid?
the sides closest to the camera and all the way in the back...
thought it was ply with banding on it
www.worldllc.net
Old 09-29-2009, 08:54 PM   #9
Faking my Way
TBFGhost's Avatar
Originally Posted by world llc View Post
oh...so it's solid... ok i get it
thought it was ply
No, its ply, none of that is solid cherry. I applied the vert. 45 and then put a solid veneer over it all so it looks solid. Yes, you can see the poplar veneer in the dados, but the stain made it is "like" color and the client didn't want to spend a fortune and will be more then happy.
Old 10-15-2009, 06:32 PM   #10
Faking my Way
TBFGhost's Avatar
Here it is sitting in use....the plans are for me to build an entire matching office set-up...so that means, desks, file cabs...etc etc....
Metal Shelf bins WarnerConstInc. General Discussion 8 07-05-2009 02:52 PM
Blind shelf supports JohnV Finish Carpentry 4 02-18-2008 06:31 PM
Corner Book shelf Higgs Finish Carpentry 9 01-31-2008 08:01 PM
Tile shelf ODDBALLS Remodeling 4 09-26-2007 10:09 PM
Adding a brick shelf mant Masonry 4 01-06-2007 09:36 PM
