Wooden Canopy
Old 01-28-2009, 05:01 PM   #1
dbryant11's Avatar
Trade: Custom Home Builder
Wooden Canopy
Guys, sorry, but I've been searching for days, and can't find if this has been covered in the past, but can anyone give me some advice on the best way to attach something like this to a house? No masonry, all wood with vinyl siding. Thanks, and I just want to make sure it doesn't fall off...... thx.
dbryant11 is offline
Old 01-28-2009, 05:08 PM   #2
D.Foster's Avatar
Trade: Carpentry & Remodeling
Re: Wooden Canopy
Pull the vinyl off and bolt to framing. Then re attach vinyl around the roof with your preferred trim and step flash. J-channel might look alittle weird around the corbel brackets tho
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 01-28-2009, 07:20 PM   #3
Kaiser's Avatar
Trade: Project Management
Re: Wooden Canopy
I'm trying to figure out why anyone would want to attach that thing to any building.
But if your determind to do so try wonder putty.
"Go confidently in the direction of your dreams. Live the life you have imagined."
Henry David Thoreau
Kaiser is offline
Old 01-28-2009, 07:25 PM   #4
Forry's Avatar
Trade: General Contractor, Remodeler
Re: Wooden Canopy
That pictures a mystery. Why is it on the side of a building with no door, window, or anything. Maybe it's a Harry Potter door?
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Old 01-28-2009, 07:45 PM   #5
s. donato's Avatar
Re: Wooden Canopy
can you use posts and incorporate it into the landscaping?
this is one i did last year
http://picasaweb.google.com/saldonat...81921423152866
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County.
Bergen County's Premier Home Maintenance Provider.
s. donato is offline
Old 01-28-2009, 08:25 PM   #6
dbryant11's Avatar
Re: Wooden Canopy
Sorry, the pic was supposed to clear, rather than muddy the water. I'm wanting to put a small "canopy, roof, overhang" over a front door, and figured (perhaps incorrectly) that a picture would be easier than trying to explain it. That's what I get for thinkin'. Its a very small house, 16' wide, 2 story, and I don't want a full width "porch." I'm also trying to not have support posts, since the doorway is only 36" without sidelights, and therefore is small, and I don't want to crowd the front "stoop" with posts, making it appear even more narrow. This is just a pic I found on the web that close to what I'm thinking. I also haven't even done the new siding yet, which could make it a bit easier, but I wasn't sure if I needed to do anything special inside the home, between the studs or anything to carry the load down from the corbels, etc. Thanks again! (I could get different pics, showing something like this over a door if that would help.......) So yes, Donato, something like you did, only without the support posts on the outside corners.........
Old 01-28-2009, 10:03 PM   #7
President of the world
world llc's Avatar
Trade: general contractor
Re: Wooden Canopy
as a custom home builder, you shoud all ready know!
world llc is offline
The Following 3 Users Say Thank You to world llc For This Useful Post:
BigLou80 (01-31-2009), Dan_Watson (01-28-2009), Forry (01-28-2009)
Old 01-28-2009, 10:56 PM   #8
dbryant11's Avatar
Re: Wooden Canopy
Yes, I should, which is why I asked. I'm a general contractor, not a framer, and having never done one like this before, I wanted to make sure it was done correctly. Thanks in advance to anyone who knows, and can help me.
Old 01-29-2009, 12:30 AM   #9
I used to think so.......
wallmaxx's Avatar
Re: Wooden Canopy
Like "These Ones" as my CDN brethren are fond of saying. Do like was posted above. Remove as much exterior clad as required. Through bolt (if possible) into "beefy" sub-nailing members that you shall install into the framed wall and refinish.
An analogy would be like...this little roof is sticking out there like if you held a gallon of milk straight out in front of you...it just wants to go down.
wallmaxx is offline
Old 01-29-2009, 01:05 AM   #10
Re: Wooden Canopy
Yes!
You need solid framing behind
the knee braces.
The weight of the roof
as well as the weight on the roof
is pressing against the wall
at the bottom of the knee brace.
Think about it.
neolitic is offline
Old 01-29-2009, 01:21 AM   #11
Bodger's Avatar
Re: Wooden Canopy
Whether he should or shouldn't, who gives a f*&k?
He's asking for help and speaking like a gentleman.
Has there ever been anything you didn't know that you should have?
Bodger is offline
The Following 4 Users Say Thank You to Bodger For This Useful Post:
BattleRidge (01-30-2009), Deadhead Derek (01-29-2009), Tom Struble (01-29-2009), VMFehr (02-11-2009)
Old 01-29-2009, 01:29 AM   #12
BuiltByMAC's Avatar
Trade: Construction
Re: Wooden Canopy
If you're unsure of your abilities to cut a structurally-sound curved knee brace, consider extra bracing
(either wood 2x2 or metal pipe assembly) following the red lines:
from crotch of support posts to back middle of the curved knee brace.
Yes, as Neo said - chunky blocking in the wall to distribute the load.
Mac
BuiltByMAC is offline
Old 01-29-2009, 01:34 AM   #13
Bodger's Avatar
Re: Wooden Canopy
...And the through-bolts as mentioned above, if at all possible and wherever possible.
I've demo'd a rig like this and found loose lags that didn't hold up well.
Bodger is offline
Old 01-29-2009, 08:34 AM   #14
Tom M's Avatar
Re: Wooden Canopy
Solid framing will pick up the wieght behind the sheathing. I have put 2x3 verticle cleats along sides of the exisitng studs then used horizontal solid blocking against those cleats to transfer the load. Depending on your situation you can put a full size 4x4 or4x6 against the house verticly from landing to roof and brace to that. Connect any rafter or ridge to the house like you would a ledger board. Headlocks can make a nice neat connection for the braces.
Tom M is offline
Old 01-29-2009, 05:51 PM   #15
D.Foster's Avatar
Re: Wooden Canopy
Wall maxx,looks good. Bummer that the siding didnt line up.
D.Foster is offline
Old 01-29-2009, 09:41 PM   #16
dbryant11's Avatar
Re: Wooden Canopy
Thanks ALL! I appreciated all your comments, and helpful advice. I even appreciate the reminder of the responsibility I assume when taking on the title "Custom Home Builder" so thanks. Wallmaxx that's very close to what I'm thinking. The real good news, is the house is gutted inside, so the blocking will be a piece of cake, as I'm reframing around a new front door anyway. Thanks! For what its worth, feel free to check out some of my other projects under General Discussions, Post a Picture of your Current Job. I'm on page 31, in the middle.
Thanks again, and I'll post a pic of the final.
Old 01-30-2009, 12:07 AM   #17
wallmaxx's Avatar
Re: Wooden Canopy
Tell me about it. It's 100 years old. I had to look all over Houston to try and find a matching profile. No luck. So we carefully removed just enough in big enough pieces to re use. What a pain. The HO was understanding though.
wallmaxx is offline
Old 01-30-2009, 12:35 AM   #18
Tom Struble's Avatar
Trade: siding
Re: Wooden Canopy
thats pretty nit picking
Wall max what is the siding material in the 2nd picture?looks unusual
Tom Struble is offline
Old 01-30-2009, 06:14 PM   #19
D.Foster's Avatar
Re: Wooden Canopy
Uhhh. Maybe, but that would be the first thing asked of me by many of my clients. I am glad that they were understanding Wall, didnt mean to be nit picky. Didnt expect that comment from a SIDING guy though!
D.Foster is offline
The Following User Says Thank You to D.Foster For This Useful Post:
Tom Struble (01-30-2009)
Old 01-30-2009, 08:14 PM   #20
Trade: siding
Re: Wooden Canopy
sorry,your right it should line up dont know what i was thinking.
I guess from seeing it on the ground then on the wall impressed me
D.Foster (01-30-2009)
from carpeted to wooden stairs robtlem Finish Carpentry 24 03-14-2009 08:26 AM
century old wooden doors joeslob Sandblasting 8 01-25-2009 03:08 PM
wooden door installer,lock installer john osler Introductions 7 01-09-2009 08:38 AM
Wooden privacy fence gates ks4tm Decks & Fencing 1 10-21-2008 06:22 PM
new wooden floors over concrete?? remodeling joe Flooring 7 03-19-2007 12:17 AM
