Wood French Door Repair?
Old 01-21-2007, 10:09 PM   #1
Mod / ArchiBuilder
Cole's Avatar
I have a client whose wood fench door is in need of repair on the bottom part.
Can you take them apart?
If so, how hard is it?
I know I can have the piece custom made to fit but was wondering if anyone has done this?
Cole is offline
Old 01-21-2007, 10:13 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Wood French Door Repair?
If you are refering to an interior door, most of the wood is covered with a wood veneer. Some of the exterior doors are the same way but some have real wood. The joint on interior doors are rather complex, a funky shaped joint plus dowels, so you would have to locate the dowel, remove them and then seperate the joint. The exterior doors are a different monster.
dougchips is offline
Old 01-21-2007, 10:26 PM   #3
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
Are you talking about the bottom of the door itself? like a door with real panels?
It must be a RRRREEEEAAAAALLLLL nice door to take it apart and fix. It would be an absolute nightmare.
How bad is it damaged?
Real nice guys
King of Crown is offline
Old 01-21-2007, 10:33 PM   #4
Mod / ArchiBuilder
Cole's Avatar
We are talking about an exterior door.
It has rot from a broken window.
Cole is offline
Old 01-21-2007, 10:39 PM   #5
Heavy Weight Champ
Is it old, and they really like it? I cant imagine it being worth fixing unless they were absolutely in love with it.
Real nice guys
Old 01-21-2007, 10:40 PM   #6
Insert title
dougchips's Avatar
What brand is it? You should be able to order a new panel if it is Andersen or Pella. If it is an Atrium, just replace the door.
Old 01-21-2007, 10:42 PM   #7
Mod / ArchiBuilder
Cole's Avatar
It is pretty old.
I cant even find out the manufacturer.
Cole is offline
Old 01-21-2007, 10:51 PM   #8
Insert title
dougchips's Avatar
Time for a new door then unless you want a real challenge.
BTW. most of the Production french hinged doors will have a name on the hinges.
Old 01-21-2007, 10:55 PM   #9
Heavy Weight Champ
Side-bar, I love Atrium doors.
back on subject, It might be worth fixing if they are really old. But you can get a door company to make a new door that is exactly the same for the cost of fixing the old one.
Real nice guys
Old 01-21-2007, 11:07 PM   #10
Insert title
dougchips's Avatar
King, when I drive up to a house to measure for a patio door and the house is 5-20 years old I know that they have an existing Atrium door. 100% of the ones that I've changed have rotten bottom panel and the water flows through the sill. Not sure if they send the defective ones to new england, but I would not use one. I'll give you this, they make a pretty door. The ones that they sell at home crepo with sidelights are crap also, if the door is sqaure then the venting sidelights are not. Also the wood finish is a little rough.
Old 01-21-2007, 11:10 PM   #11
Heavy Weight Champ
I installed some the other day that had a new hinge system on them. It worked really cool, but that is all I really know about them, except that they were way over priced. The hinges on it seemed to be revolutionary though.
But water damage on doors is a rare find around here.
Real nice guys
Old 01-21-2007, 11:16 PM   #12
Insert title
dougchips's Avatar
Correct, they do have the best hinge design that I have ever seen. The last one I installed was last summer and the adjustable hinge system made up for the door not being built square.
Did you have daylight where the seams on the cladding came together? For some reason their seams push out on the compression weather stripping enough to create a little daylight. Did the wood veneer have round sanding marks that looked like they sanded it with 80 grit?
Old 01-22-2007, 10:06 AM   #13
Heavy Weight Champ
yes.
this particular door had glass in it, and there were circles in the glass from th esander. And there was some light that came in, I just added a dust pad behind the weatherstripping though, and it took care of it.
Real nice guys
Old 01-25-2007, 12:55 PM   #14
Mod / ArchiBuilder
Cole's Avatar
Ok, we are going to try and replace the door.
The problem I am running into now, is the door was made by The Atrium Door Company and they went out of business in 1997.
So now, I am going to have to get the door custom made.
Cole is offline
Old 01-25-2007, 01:17 PM   #15
Insert title
dougchips's Avatar
Atrium still makes door, that baffles me. What is your RO and do they want a sliding door or hinged? Also do they want a wood interior?
Old 01-25-2007, 09:51 PM   #16
Mod / ArchiBuilder
Cole's Avatar
http://www.allaboutdoors.com/article...articles_id=35
The atrium door company, out of the wooden-door business since 1997
, left behind a legacy of nicely crafted doors, which are now beginning to show their age. Fortunately, there are several things you can do to make your door look and work almost like new.
Allaboutdoors.com ( http://www.allaboutdoors.com ) has many of the items you will need to restore your door.
Cole is offline
Old 01-25-2007, 10:16 PM   #17
Insert title
dougchips's Avatar
http://www.atriumpatiodoors.com/
Old 01-25-2007, 10:28 PM   #18
Heavy Weight Champ
Yeah, we were just talking about them. I like that http://allaboutdoors.com
Real nice guys
Old 01-25-2007, 11:32 PM   #19
Mod / ArchiBuilder
Cole's Avatar
I am guessing they were bought out by Woodgrain Millwork.
So I should be able to order it through them and they have a location here in Dallas.
Cole is offline
Old 01-27-2007, 09:52 AM   #20
brownie77's Avatar
Trade: Carpentry, Contractor Sales for Pella Window and Door
I'm with you Doug! I've replaced and sold countless rotten Atrium wood sliders and hinged patio doors. House built during the mid to late 80's to mid 90's. Those fingerjointed frames just can't hold up to the elements. You pull the door frame out of the opening in 10 pieces...
brownie77 is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
French drain question 72chevy4x4 Construction 4 11-01-2006 10:46 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 09:07 AM
Really Dark Wood...Primer/Application Q slickshift Painting & Finish Work 13 04-28-2006 04:47 PM
