Window Under Deck
Old 07-24-2006, 08:56 PM   #1
gregt848's Avatar
Trade: Painter Residential and new Construction
Window Under Deck
Hello, I have a question that I hope someone can shed some advise on. I Currently have a deck that I am ripping down and replacing because it is rotted, old and falling apart. The new deck will basically stay in the footprint of the original. Under the deck is a basement window that the dryer is vented out of. The window is wooden and old and also needs replacing. My question is should I continue venting the dryer out the window under the deck, or will the moisture affect the new deck. I will be using pressure treated lumber but i still want to do it the correct way. if i am to re-route the dryer vent now is the time to do it. If it is O.k. to still vent out that window I would rather do it that way. The rough opening is 19" X 36" is that a common or standard size? If anyone can shed some light it would be greatly appreciated. I am posting this question as well in another section. Thanks,
gregt848 is offline
Old 07-24-2006, 09:02 PM   #2
Peladu's Avatar
Re: Window Under Deck
Dryer vent that vents out of a window?
Why not make a penetration through the wall, 4" hole and use that for the vent.
I may be reading this wrong, but I just wanted to type penetration at least once on this site. OK twice.
Peladu is offline
Old 07-25-2006, 06:30 AM   #3
ContractorTalk Flunkie
dayspring's Avatar
Through the window? Seems a bit tacky to me, no offense. I agree, go through the wall. If you have enough air space under the deck the air from the vent shouldn't be a problem at all.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 06:29 PM
casement window stripping and deck wash wallyofthenorth Painting & Finish Work 6 05-12-2006 02:36 PM
