Window Install In Block
Old 03-11-2006, 08:12 PM   #1
EdenScapes
EDENSCAPES@DNET's Avatar
Trade: PAINTER,LANDSCAPER
Have a customer with a rental house just remodled. Now the building inspector says a window must be installed. House is block and I'm looking for the easiest way to install the window. Just this week finished installing a door through a block wall crawlspace, on a new home. The opening was the wrong size and the completed job looks great, but had to enlarge the length of the opening and it took a while. I end up fixing others mistakes and you know how long that can take. Any one with experience that could help I thank.
Eden Scapes
EDENSCAPES@DNET is offline
Old 03-11-2006, 08:25 PM   #2
Teetorbilt's Avatar
Re: Window Install In Block
Once again, WHERE ARE YOU? I'm in FL and I'm sure that my codes are different from someone in the Dakotas.
Albert Einstein
Teetorbilt is offline
Old 03-11-2006, 09:58 PM   #3
EdenScapes
Sorry about that - South west North Carolina Teeterbilt.
Eden Scapes
Old 03-11-2006, 11:30 PM   #4
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Sub it out. That's easiest. I assume you need to cut the hole? Buy or rent a saw or grinder that will accomodate a diamond blade for the depth of the block.
JustaFramer is offline
Old 03-11-2006, 11:57 PM   #5
ContractorTalk Flunkie
dayspring's Avatar
Edenscapes, that dnet looks familar. Are you from the Murphy area? I, myself live in Murphy. As far as installing the window goes... You can purchase a window, find the rough opening measurements, add three inches to that, cut your opening. Fasten, pressure treated material(2x) to block set in to your desired reveal. Install the window, trim with brickmold. Interior side, just trim as needed.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 03-12-2006, 09:19 AM   #6
EdenScapes
Sure do appreciate the help guys! And yes Dayspring, I live in Andrews but work mostly in Murphy, Hiawassee, Blairsville, Haysville the tri state area. If you're interested I could hook you up with this customer, I've got more than I can do right now with this early spring. Anyways could use a good remodler to recommend. I'm in the yellow book under painting and landscaping. Like the logo by the way.
Eden Scapes
Old 03-12-2006, 09:31 AM   #7
dayspring's Avatar
I'm pretty dog-gone busy myself, but I would certainly appreciate the referals. You can find all of my contact info @ http://remodelingncarolina.com Maybe we can meet soon!
T.C.
Old 03-12-2006, 10:53 AM   #8
Teetorbilt's Avatar
I don't see any mention of a lintle, is that assumed?
Albert Einstein
Old 03-12-2006, 01:33 PM   #9
General Contractor
nadonailer's Avatar
Question
Teetor - out here in SoCal where everything is stucco or wood construction, we don't use lintels (much) Is that just an exposed header? Just curious....
"History does not long entrust the care of freedom to the weak or the timid”.
Dwight D. Eisenhower
nadonailer is offline
Old 03-12-2006, 02:08 PM   #10
dayspring's Avatar
Good point Teetor, Absolutely a necessity. Sorry I didn't add that on my post
T.C.
Old 03-12-2006, 02:09 PM   #11
dayspring's Avatar
A lintle serves the same purpose as a header, only it's plate steel, used with masonary. I'm sure Teetor has dealt with a few.
T.C.
Old 03-12-2006, 02:32 PM   #12
EdenScapes
Yeah, appreciate that, I assumed a header would be necessary but forgot about the block needing a lintel. And yeah Dayspring we'll get together sometime, sounds good.
Eden Scapes
Old 03-13-2006, 08:41 AM   #13
Teetorbilt's Avatar
Most of the homes that I deal with are block. For short spans we typically use pre-cast concrete or sometimes pour in place. For longer spans, steel I-beams are the norm.
Albert Einstein
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Need Help On A Window Install Estimate bkn4x4 Windows, Siding and Doors 17 05-23-2007 04:16 PM
Cost of Install Exterior Door in Place of Window Jacey Carpentry 41 04-21-2007 08:30 AM
Cutting Window openings in block HemiMan2500HD Masonry 6 03-20-2007 10:33 PM
Need Help On A Window Install Estimate bkn4x4 Construction 1 03-11-2007 04:23 AM
